3D Printing
Here is a selection of 3D printing ideas and parts:
See here for 3D printing related threads: http://www.xsimulator.net/community/forums/3d-printing.158/
Enclosure for Arduino uno R3 + 3 IBT 2 BTS by @poumpouny: https://www.xsimulator.net/communit...bt-2-bts-7960-motor-driver.18380/#post-245108
Wheel Quick Release by @Mechatronik: https://www.xsimulator.net/community/threads/my-quick-release-stl-files.17147/
SFX 100 EMI Reduction Power Box, including parts list by @WedgeSD: https://www.xsimulator.net/communit...otion-drivers-interference.16885/#post-227927
Sabertooth enclosure by @xxpelle: https://www.xsimulator.net/communit...-with-standard-parts.13504/page-2#post-192710
Pneumatic G-Seat 3D printed integrated bladder/servo/Arduino mount by @xxpelle: https://www.xsimulator.net/community/threads/update-pneumatic-g-seat.14306/#post-192428
HP Reverb Prescription Lens Adapter by @Historiker: https://www.xsimulator.net/community/threads/hp-reverb-prescription-lens-adapter.14062/
How to print SFX parts in under 100 hours, by @diablo2112: https://www.xsimulator.net/communit...4-axis-sfx-100-build.13571/page-3#post-185076
Bracket for Pololu JRK G2 12V27: https://www.thingiverse.com/thing:3837389
Thrustmaster T500 QR wheel adapter (direct mount): https://www.xsimulator.net/community/threads/thrustmaster-t500-qr-wheel-adapter-direct-mount.13530/
3D printed VR HMD mount: https://www.xsimulator.net/community/threads/hmd-chair-mount-holder.13123/
Quick Mounts For HTC Vive Lighthouses by @Zed: https://www.xsimulator.net/community/threads/quick-mounts-for-htc-vive-lighthouses.11941/
3D printed mount by @CBC_North: https://www.xsimulator.net/communit...mover-with-diy-peripherals.12178/#post-163742
3D printed pot mount by @digitalmonk: https://www.xsimulator.net/community/threads/3dof-seat-mover.11103/#post-143599
DIY linear actuator parts by @baykah: https://www.xsimulator.net/community/threads/6dof-sim-linear-actuator-diy-sabertooth-arduino.9392/
Power Entry Module Housing by @Zed: https://www.xsimulator.net/community/threads/power-entry-module-housing.10584/#post-137108
3D printed H-Shifter + shifter & buttons for race wheel: https://www.xsimulator.net/communit...shifter-shifter-buttons-for-race-wheel.10379/
JRK underside board cooler mount by @Zed: https://www.xsimulator.net/community/threads/jrk-12v12-overheating.10327/#post-133739
Touch controller mount by @Azel for use with motion cancellation: https://www.xsimulator.net/communit...culus-touch-holder-bracket.10355/#post-133717
Pot connection coupling by @Andrew M: https://www.xsimulator.net/communit...shield-3d-printed-elements.10325/#post-134013
Wiper motor post mounts by @insanegr: https://www.xsimulator.net/communit...ts-sim-related-prints.9057/page-2#post-123997
Vive Tracker mount: https://www.xsimulator.net/communit...-vive-and-vive-tracker-a-tracker-mount.10346/
Pot mount, connector and sundry parts by @Azel: https://www.xsimulator.net/community/threads/diy-2dof-made-mostly-of-scrapyard-parts-and-top-quality-electronics™.10326/
Hall sensor mount, mag mount and U joint spacer by @Zed: https://www.xsimulator.net/community/threads/starting-my-own-2dof-rig.10235/page-3#post-132900
And Amp gauge box: https://www.xsimulator.net/community/threads/starting-my-own-2dof-rig.10235/page-3#post-132988
Dsub 15 for OSW builds, submitted by @Nick Moxley: https://www.xsimulator.net/community/threads/dsub-15-for-osw-builds.9385/
Honeycomb fan air straighteners by @Avenga76: https://www.xsimulator.net/community/members/avenga76.10691/
Modified snap on honeycomb fan air straighteners by @HoiHman: https://www.xsimulator.net/communit...ermoto-and-arduinouno.6876/page-9#post-114138
Moto Monster ventilated box by @Avenga76: https://www.xsimulator.net/communit...ermoto-and-arduinouno.6876/page-7#post-113677
Moto Monster ventilated box with internal fan by @Avenga76: https://www.xsimulator.net/communit...ermoto-and-arduinouno.6876/page-9#post-114400
Combined 3D printed Arduino case with dual Motor Monster wings by @stevemontuno : http://www.thingiverse.com/thing:1510217/#files
Moto Monster slide on 80mm fan holder by @HoiHman: https://www.xsimulator.net/communit...rmoto-and-arduinouno.6876/page-10#post-114424
3D printed file for custom All in one 3 X PSU and JRK Cooler Master Elite Case Mod: http://www.xsimulator.net/community/faq/all-in-one-3-x-psu-and-jrk-cooler-master-elite-case-mod.199/
Download 3D files by @rundmg here: http://www.xsimulator.net/community...f-simulator-conversion.5914/page-4#post-89608
3D quick release steering wheel hub by @RacingMat: http://www.xsimulator.net/community/threads/3d-printed-quick-release.6360/#post-70710
If you like your creature comforts then here is a cup holder and bracket by @HoiHman: https://www.xsimulator.net/community/threads/drinking-cup-cupholder.9103/
Below is a summary of a diverse range of 3D Printed objects made available by @Ville Pesonen in one package: http://www.xsimulator.net/community/threads/2dof-motion-simulator-build.6196/page-7#post-88219
CapHolder
It's basically a mount for a nut that you can screw to somewhere.
Case:
Never managed to print this...
Diode Holder:
I used this to keep 2 diodes in place to stop reverse current reaching the PSU's
Gas spring mount:
Part to hold gas spring in place. It clamps around 30x30mm tube
HBridge Holder:
You can screw a cheap chinese H bridge to this
MonsterMoto holder
You can screw monster moto shield to this
Coulus Camera holder:
This part slips inside 30x30mm tube and has a hole in the middle for a camera mount screw.
Potentiometer connector
just a tube that goes over the potentiometers shaft and can be glued to the shaft of a motor
Potentiometer holder:
I used this to mount potentiometers next to the motor. the holes are in line with the motor mount holes. I can't remember the model of the motor that I have...you can find it somewhere in this build thread.
PsuHolder
Never used this, but it was meant to hold the psus in place.
SwitchHolder
little part to hold a power switch in place
Building Resources
Apr 21, 2015
9666
