Tutorial 24v motor driver - where to buy
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pit, Jun 12, 2015.
  1. Pit
    30,438Coins
    BB-VNH3SP30 = $ 12 (single motor driver) Please read carfully here
    https://www.olimex.com/Products/RobotParts/MotorDrivers/BB-VNH3SP30/open-source-hardware
    Code:
    FEATURES
        Up to 30A loads
        5.5-36VDC power supply
        STATUS PWR LED
        STATUS direction LEDs
        Can work with 5V Arduino boards
    VNH5019 = $ 50.- ($ 25 each motor)
    https://www.pololu.com/product/2507
    Code:
    Motor driver:     VNH5019
    Motor channels:     2
    Minimum operating voltage:     5.5 V
    Maximum operating voltage:     24 V2
    Continuous output current per channel:     12 A
    Peak output current per channel:     30 A
    Current sense:     0.14 V/A
    Maximum PWM frequency:     20 kHz
    Reverse voltage protection?:     Y
    Sabertooth dual 12A motor driver = $ 80.- ($40 each motor)
    http://www.dimensionengineering.com/products/sabertooth2x12
    Code:
    Specifications:    12A continuous, 25A peak per channel
    Up to 24V in
    Synchronous regenerative drive
    Ultra-sonic switching frequency
    Thermal and overcurrent protection
    Lithium protection mode
    Input modes: Analog, R/C, simplified serial, packetized serial
    Double BTS7960B DC 43A Stepper Motor Driver = $ 11.-
    http://www.ebay.com/itm/Double-BTS7...ridge-PWM-For-Arduino-smart-Car-/200950936475
    Code:
    Specification:
    Double BTS7960 (43 A);
    5V isolate with MCU, and effectively protect MCU;
    5V power indicator on board;
    voltage indication of motor driver output end;
    can solder heat sink;
    Just need four lines from MCU to driver module (GND. 5V. PWM1. PWM2);
    isolation chip 5 V power supply (can share with MCU 5 V);
    Size: 4 * 5 * 1.2 cm;
    Able to reverse the motor forward, two PWM input frequency up to 25kHZ;
    two heat flow passing through an error signal output;
    isolated chip 5V power supply (can be shared with the MCU 5V), can also use the on-board 5V supply;
    the supply voltage 5.5V to 27V
    3-36V Dual 15A H-Bridge DC Motor Driver 30A = $20
    http://m.ebay.com/itm/111140003697
    Code:
     Module Specifications:
    The motor is transferred: DIR = 1 PWM = PWM
    Motor Reverse: DIR = 0 PWM = PWM
    Parking brake: DIR = X PWM = 0
    Motor and power connections
    Power to Positive POWER, GND to negative one. Two motors to MOTOR1, MOTOR2
    Rated voltage: 3v-36v
    Rated current: 15A
    Peak Current: 30A
    Dimensions: l10 *58 mm
  2. Pit
    30,438Coins
    UPDATE: I decided to create a shopping list - any more sources are welcome (already added to the FAQ as well).
  3. eaorobbie
    20,431Coins
    Beware the pololu and BB-VNH3SP30 are very fussy when running at 24v , if input power surges up they will immediately shutdown.
  4. Pit
    30,438Coins
    Found this on Pololu forums: "While VNH3SP30’s over-voltage shutoff doesn’t activate until 36 V, in our experience, shoot-through currents make PWM operation impractical above 16 V".
  5. eaorobbie
    20,431Coins
    Played with both on 24v , just letting ya know what I found with them, My fav was the Sabertooth , with a fan over it didn't miss a beat, just not a cheap option, had to run the 25x2 on it thou.
    Im sure a Chinese unit exists that can keep up with them. Well I hope there is.
  6. Pit
    30,438Coins
    in my case unfortunately the sabertooth are pretty expensive it would become cheaper to use a worm gear instead the planetary gear in combination with a strong 12v motor like the winches (750W and more) and the cheap but approved MMs.
    • Agree Agree x 3
  7. EleaSkipper
    EleaSkipper New Member
    - 45Coins
    I have an Arduino uno and 3 BTS7960 IBT2 40A , how to manage connect all the drivers wires to one Arduino? is the pins enough for 3 drivers?
