Tutorial Arduino: noisy motors while not moving? Check this out.
Discussion in 'Motor actuators and drivers' started by Pit, Mar 22, 2015.
  1. Pit
    30,490Coins
    Hi
    Again I want to help any members here by sharing the knowledge given to me, if you have similar issues: noisy motors while they are not moving. Although I am very familiar using the Arduino I was wondering all the last months why my motors are so noisy while they did not move. I had never the time to dig deeper into the source of that annoying "feature", until @RacingMat had coded and linked a new code for the Arduino "Utrasonic" which gave me the input to fiddle it out.
    While I am using SMC3 due to the nice utility and myself approved code I asked @RufusDufus about any details of his Arduino code, which sends 20kHz PWM and higher (instead of standard 490Hz PWM - thanks @RacingMat for that) to reduce the noise.
    He explained, that
    "two parameters in SMC3 that are most likely to cause noise in the motor windings (buzzing or humming type noise) are the Kd and PWMmin values. This type of noise is most noticeable when the motors are holding position and not moving. If the noise you are getting is mostly when moving (unless slow smooth movement) it is probably not from the PID".
    So far we know from where we expect the source of the noise. But what can we do?
    His response so far:
    "Kd values cause the PWM duty cycle to rapidly change positive to negative as the system tries to compensate for errors. This can create harmonics in the windings causing noise. There are two ways to minimise this
    1. use a very small Kd value (0 completely eliminates these effects - but results in no damping effect)
    2. Increase Fpid, this is a divider that reduces how often the Kd parameter will update the PWM calculation - specifically added to help combat motor noise.
    PWMmin values has a similar effect because when the PWM drive changes direction it is not a smooth transition as the PWM duty ramps down to zero then raps up in the other direction. It ramps down to the PWMmin and then jumps to PWMmin in the other direction. So you get a stronger drive but potentially with more motor noise.
    Thanks a lot @RufusDufus for detailed explanation, I hope adding this knowledge should reduce any further support in future if this issue will be discussed.
    BTW my SMC values are for the
    Seat (two 750W motors):
    Fpid / 2
    Kp = 500
    Ki = 0
    Kd = 0
    Ks = 1
    Fpwm = 20kHz
    PWMmin =0
    PWMmax = 200
    PWMrev = 190
    Max Limits = 110
    Clip Input = 180
    Deadzone = 0
    Traction loss (one 200W motor):
    Fpid / 2
    Kp = 500
    Ki = 0
    Kd = 0
    Ks = 1
    Fpwm = 20kHz
    PWMmin =0
    PWMmax = 205
    PWMrev = 200
    Max Limits = 20
    Clip Input = 150
    Deadzone = 0
    Settings shared by @RufusDufus
    Fpid / 4
    Kp = 700
    Ki = 0
    Kd = 80
    Ks = 10
    Fpwm = 20kHz
    PWMmin =0
    PWMmax = 220
    PWMrev = 210
    Max Limits = 20
    Clip Input = 150
    Deadzone = 0
    Many thanks to @RufusDufus again for the time he has taken.
    • Informative Informative x 11
    • Disagree Disagree x 1
  2. ericRacer
    ericRacer You get old because you stop playing ! Gold Contributor
    Pilot
    Canada, Quebec
    952Coins
    thanks for taking the time for sharing this information/explanation. :thumbs
  3. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    Is it sounds like knock from time to time?
  4. Pit
    30,490Coins
    no, this is normal and usually happens.
  5. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    thanks for your explantation. I understand where the noise comes from, but can this damage the Motors? The reason I'm asking is, I have tuned my PID settings again at the weekend. Now they are very aggressive and I like this settings much. But sometimes there is the noise when motors are holding the position. As I'm happy with this settings and waering a headset while gaming I can't hear the noise. So I would let my settings as they are, but i don't know if this can damage the motors for time.
  6. Cvetan Cvetanov
    Teteven Bulgaria
    1,462Coins
    Motors no, but reductor will wear
  7. Pit
    30,490Coins
    Pardon?
  8. Cvetan Cvetanov
    Teteven Bulgaria
    1,462Coins
    gears will wear if they are overloaded.
  9. AlexinChina
    AlexinChina Member
    China
    371Coins
  10. Pit
    30,490Coins
    • Funny Funny x 5
  11. RacingMat
    21,050Coins
    Are you hearing me????
    • Funny Funny x 2
  12. SeatTime
    I've likely read this all wrong, but are you using a cap on your feedback line to earth to get rid of noise?
  13. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    I tested my project and I saw the same issue "noise"
    Can be use the induction motor with magnetic stop?
    maybe this noise caming from the brush motor, they can't hold the position well
    without spend a lot of power and the accuracy to stop I think that some motor like "wiper or other gearbox" on the shaft have gap between the contact to brush is to big than when the motor trying hold this position don't have a good contact.
  14. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Thank for sharing.
    Now My 2dof project is louder noise and not smooth.
  15. Pit
    30,490Coins
    So go back to former settings...
  16. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Low noise give less power but hight power has lounder and not smooth graph
    Fpid / 1
    Kp = 660
    Ki = 0
    Kd = 0
    Ks = 60
    Fpwm = 20kHz
    PWMmin =0
    PWMmax = 245
    PWMrev = 240
    Max Limits = 20
    Clip Input = 150
    Deadzone = 0
  17. Peter_the _machinist
    Peter_the _machinist Member
    Mechanical Engineer (CAD,CAE)
    Poland, Gdańsk
    359Coins
    1.Does this @RacinMat code will work for BTN8982??? In theory I found in datasheet that BTN8982 supports up to 20kHz but I do not know anything about electronics so I rely on you guys.
    2. Is this code overwrite standard SMC.ide code? 3. Do I need to make changes in downloaded @RacingMat's note?
  18. RacingMat
    21,050Coins
    hi :)
    I never used SMC sorry.
  19. Qui
    Qui New Member
    - 144Coins
    adjust Fpid / 1 ===> Fpid / 10
  20. Stefzouille
    Stefzouille Member
    595Coins
    2DOF, DC motor, 4DOF
    Hi, I was able to lower the noise a little by playing with the settings. only I loaded a 40kg weight on it, and the noises started again. the problem is that in the end it's more than 150kg me with who will have to lift... in diy actuator e30-150 motors 750w mode, the gear ratio is not very strong..
    here are my current settings my parameters for the smc3 utils:
    Fpid: 7
    Kp: 150
    Ki: 15
    Kd: 0
    Ks: 30
    Fpwm: 20kHz
    Pwmmin: 0
    pwmmax: 150
    pwmrev:140
    maxlimit: 215
    clip in: 255
    deadzone: 0
