Out of memory error
Discussion in 'New users start here - FAQ' started by lee1970, Mar 20, 2014.
  1. lee1970
    lee1970 New Member
    Field Service Engineer
    17Coins
    Hi all , I have just spent days trying to resolve a out of memory error with frame work 4.5 causing the game engine to crash running windows 7, the issue was caused by an out of date chipset usb driver,once I downloaded the latest drivers for my motherboard the issue was fixed . hope this helps anyone who comes across this problem .
    • Informative Informative x 5
  2. RaceRay
    23,862Coins
    Thanks for sharing the useful information!
  3. yobuddy
    49,209Coins
    Yes, Thanks so much for sharing!
    I'm sure this will help others!
  4. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    Is this the same memory problem that is in the rfactor2 plugin?
  5. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    rf2 on its own hasn't got a memory problem rf2 is a 32bit application and therefore it has a max ram limit of 4gb (3,7 actually). When the total used ram exceeds this limit the game will crash....
    Maybe this also got somthing to do with it on the other hand Logykal and x-sim are much more demanding on resources haven't got this problem.. so lets wait till a solution is found.
