SIMXPERIENCE stage series with SX3000 controller
Discussion in 'SimTools compatible interfaces' started by cpvasconcelos, Aug 26, 2014.
  1. cpvasconcelos
    cpvasconcelos New Member
    208Coins
    SCN5
    Hello all.
    I am still in doubt, this is why I am posting here asking for help.
    1. Is it possible to use, without any risk, a rig from SIMXPERIENCE with SIMTOOLS ?
    (I currently own a stage IV series).
    2. If so, does it automatically detect the controller and you just have to configure the actuators? or how does it work ?
    Thank you.
  2. bsft
  3. Macka
    Macka Member
    Aerial Photographer
    Brisbane, Australia
    - 43Coins
    2DOF, SCN5
    Works great.......been using it with simtools since Value1 set up the scn5s for it. I use it exclusively with simtools for all my flight sims. Can't use it for my racing sims with simtools, so have to go back to original Simx for Asseto Corsa. Set up the actuators and dial in your own preferences. It won't cause any damage just make sure you set max limits to 95% to not overdrive the actuators. Which you need to do in simX as well if you make your own individual profiles....if I remember correctly (its been Awhile). If you need help msg me or ask questions in this post.
    My settings 2DOF
    In Game engine>>Interface settings
    Output type>>select SCN
    Interface 1>>Com3>>Packet rate 8>>Assigned Axis--Axis 2
    Interface 2>>Com4>>Packet rate 8>>Assigned Axis--Axis 1
    Interface 3 should be your slide/drift and should be Com 5 I assume.
    Your coms may vary....check in device manager for SimXperience com settings and use same.
    I set Speed about 1/2...ie 10076 ea
    Acceleration 500 (I use these speed and Accel for my flight sims...usually higher for car racing sims.
  4. bsft
  5. Macka
    Macka Member
    Aerial Photographer
    Brisbane, Australia
    - 43Coins
    2DOF, SCN5
    Because its hard to use if I don't have the coins to download it,lol ....and as I am a long time member but not so chatty I haven't earnt the points yet:p I knew someone would bite....sorry but still chuckling to myself.
  6. bsft
    check your coin count
  7. Macka
    Macka Member
    Aerial Photographer
    Brisbane, Australia
    - 43Coins
    2DOF, SCN5
    Cheers bsft, you legend.....thanks :)
  8. yobuddy
    49,207Coins
    Scn6's supported in the next version of SimTools also!
  9. nclabs
    196Coins
    Do you already know when it will be released?
  10. cpvasconcelos
    208Coins
    SCN5
    Gentlemen, thank you all very much for your support.
    I have not tried it yet, but will now see how I can download the plugin with my limited coins, because I think all the angels have done their good actions today :)
    In the meantime, please check a small footage I did with x-plane 10
    here these amazing graphics (real satellite images):
    and here some motion (more evidente in minute 3:00 and forward):
    Thanks again and thumbs up for this forum!
  11. cpvasconcelos
    208Coins
    SCN5
    NOTE : I just purchased the 29 eur month access, I think you guys do a great job and desserve my support.
    Cheers.
  12. cpvasconcelos
    208Coins
    SCN5
    Just wanted to confirm to everyone (and also thank) - all is working 100%.
    Xplane 10- 64bits, Simtools providing motion with simxperience rig, great feeling!
    Thanks.
    Question: can Simtools also control buttkickers?
  13. noorbeast
    148,004Coins
    +10,884 / 54 / -2
  14. ericRacer
    ericRacer You get old because you stop playing ! Gold Contributor
    Pilot
    Canada, Quebec
    989Coins
    Nice setup !
    Let me ask you. How and why do you use Simtool instead of Simcommander?
    about your profile in X-plane during a turn (left / right) your seat should return to the upright position. Plane, when the turn is well coordinated, there is no lateral force. There is a lateral force only when the turn is not coordinated (skid in Turn ). The little ball in the "Turn & Bank" show you how you perform/feel in the turn) . You will feel a force too when you initiatiate the turn.
  15. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    I just want to know the other way around ?
    I took over a second hand early starter kit from simexperenice but I can't get simcommander 3 to work.
    I had contact with Bernie and Kevin and got a simcommander 3 licence key but I can't get simcommander 3 to work with my simulator.
    Bernie says that there were several different starter kits in the beginning and he doesn't know witch one I have, Even do I gave him the simxperince serial numbers of the actuators.
    So I am very interested what is inside the SX3000 box ?
    Anybody of you SX3000 owners can tell me ?
  16. Mavness
    Mavness New Member
    178Coins
    3DOF, SCN5
    I followed those directions and have tried many other combinations, but I get nothing. No error from the simtools software, nothing. I see the actuators in device manager, but I still cannot get anything to move.
    Can someone please help me out? Thanks!
    EDIT: I have an SX4000, in case that matters
  17. Macka
    Macka Member
    Aerial Photographer
    Brisbane, Australia
    - 43Coins
    2DOF, SCN5
    Hi . Is it working ok with SimXperience software at the moment. Sometimes mine would just stop with Simxperience as well....usually unplugging the box and usb and doing a reboot and re plugging it all back in would fix the problem. It would also happen occasionally with Simtools and I would do a reset and reboot as above then verify it working with simXperience first before moving on to check if working in Simtools. Mine is all packed up ready to move house so I cant go through it with you until I am set up in next couple of weeks in my new house. I can go through settings as they are still in my software if I am not on the road over the next few days. Cheers Macka
  18. Mavness
    Mavness New Member
    178Coins
    3DOF, SCN5
    Thanks so much for the quick response!
    My simx has actually never needed what you described, that is to be rebooted. Also I did reboot the computer/unit a few times tonight :( Also throughout the night I would start up the simcommander software just to make sure things were working and it worked no problem.
    Thanks again for the help!
  19. Imeleon
    Imeleon Member
    Construction Engineer
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Really dumb question but I'll ask anyway. You haven't got simcommander running at the same time as simtools by any chance.
    I imagine that would cause issues.
  20. Nick Moxley
    17,055Coins
    Its been reported that both will work together.
