Showroom TM1638 and Gamedash.
Discussion in 'DIY peripherals' started by Archie, Apr 23, 2015.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Managed to get this working with help from @soraz (the code) and @eaorobbie (pin advice)
    TM1638 (China fake) with a Funduino Mega 2560. (China Fake)
    Will replace with a NANO when it arrives (another China fake.. )
    (The whole china fake thing amuses me when EVERYTHING is made in China anyway!!)
    I modified the code a little to bring the G (gear) and S (speed) display in by one Segment
    So instead of sitting on 0 and 7, then now sit on 1 and 6.
    Also made the LED's "sweep" on Start up.
    The screen is just a black piece of glass from a welders helmet. It's dark enough to not see anything until
    powered on, and lets just enough light through to look nice.
    The box is just cardboard and gaffa tape for now until I can make something better.
    The box:
    https://docs.google.com/a/fmit.com.au/file/d/0B9UVNikjcBjCUlRHdW1WOE5pOUU/view
    In action on Project Cars: (excuse the ambient noise, it's the sim coupled with one hand driving!)
    https://docs.google.com/a/fmit.com.au/file/d/0B9UVNikjcBjCOU05VTlHeTRITDQ/view
    153,866Coins
    +11,154 / 57 / -2
    Would you mind posting your modified code @Archie, I know others would be interested.
    Thumbs up for @soraz and @eaorobbie's support in getting it sorted, way to go :thumbs
  3. Archie
    Wollongong, NSW, AU
    3,797Coins
    Sure. I take no credit, all credit to @soraz for the original code, I simply added a sweep for the LED's and changed the Segment numbers.
    I could have used a loop, but I'm still getting used to Arduino, so I did it "long hand" for the LED sweep.
    Code:
             Arduino code for simple dashboard with TM1638
            // Serial parser for Interface - Output : M<Dash2>S<Dash1>G<Dash3>
            // Serial extended parser with kart racing pro : S<Dash1>M<Dash2>G<Dash3>W<Dash4>O<Dash5>F<Dash7>
            // Serial parser for Shutdown - Output : Z00
            // M : rpm              (16bit - hexadecimal output)
            // S : speed            (16bit - hexadecimal output)
            // G : gear             (16bit - hexadecimal output)
            // O : oil temp         (16bit - hexadecimal output)
            // W : water temp       (16bit - hexadecimal output)
            // F : fuel             (16bit - hexadecimal output)
            // L : lap              (16bit - hexadecimal output)
            // P : position         (16bit - hexadecimal output)
            // Z : clear            (to clear display and max rpm value)
            // for dashboard defined in TM1638.h
            // Pin xx : STB0 - strobe // Change these values in TM1638.h
            // Pin xx : CLK - clock
            // Pin xx : DIO - data
            // DashBoard include
            // module can be downloaded from http://forum.arduino.cc/index.php?topic=190472.0
            // (search TM1638_v1.02.zip)
            #include <TM1638.h>
            #include <TM1638Font.h>
            TM1638 module;
            // buttons TM1638 (left to right)
            #define btnSpeed      0b00000001 // 1
            #define btnGear       0b00000010 // 2
            #define btnRPM        0b00000100 // 4
            #define btnOIL        0b00001000 // 8
            #define btnWater      0b00010000 // 16
            #define btnFuel       0b00100000 // 32
            #define btnLAP        0b01000000 // 64
            #define btnPosition   0b10000000 // 128
            // EEPROM include
            #include "EEPROM.h"
            // variable init
            int i;
            unsigned int carspeed;      // holds the speed data (0-65535 size)
            unsigned int gear;          // holds gear value data (0-65535 size)
            unsigned int rpm;           // holds the rpm data (0-65535 size)
            unsigned int oil;           // holds the oil temp data (0-65535 size)
            unsigned int water;         // holds the water temp data (0-65535 size)
            unsigned int fuel;          // holds the fuel data (0-65535 size)
            unsigned int lap;           // holds the lap data (0-65535 size)
            unsigned int posit;         // holds the position data (0-65535 size)
            unsigned int rpmleds;          // holds the 8 leds values
            unsigned int rpmmax = 5000;    // retrieves from rpm live with minimum setting on initialization and Shutdown - Output
            unsigned int beforeButton = 0; // holds the previous pressed button
            unsigned int valButton = 0;    // retrieve the pressed buttons
            unsigned int offset = 0;       // holds the display position
            unsigned int leftButton;       // holds the pressed button (default left gear)
            unsigned int rightButton;      // holds the pressed button (default right speed)
            unsigned long timeButton;      // holds the first pressed button time
            byte speeddata = 0;         // marker that new data are available
            byte geardata = 0;          // marker that new data are available
            byte rpmdata = 0;           // marker that new data are available
            byte oildata = 0;           // marker that new data are available
            byte waterdata = 0;           // marker that new data are available
            byte fueldata = 0;           // marker that new data are available
            byte lapdata = 0;           // marker that new data are available
            byte positiondata = 0;           // marker that new data are available
            char* neutral = "n";        // sets the character for neutral
            // char* neutral = "0";        // sets the character for neutral
            char* reverse = "r";        // sets the character for reverse
            char* namesz = "StArt uP"; // sets a custom logo start up banner
            // INITIALIZATION
            void setup()
              // serial initialization
              Serial.begin(115200);
              timeButton = millis();
              // initialize the screen with leds test
              module.clear();                       // clears the display from garbage if any
              module.setChars(namesz);           // prints the banner
              delay(2000);                                 // small delay 2 sec
              // LED SWEEP - Archie
              module.setLEDs(0b00000001 , 0b00000000); // GREEN LEDS SWEEP
              delay(75);
              module.setLEDs(0b00000010 , 0b00000000);
              delay(75);
              module.setLEDs(0b00000100 , 0b00000000);
              delay(75);
              module.setLEDs(0b00001000 , 0b00000000);
              delay(75);
              module.setLEDs(0b00010000 , 0b00000000);
              delay(75);
              module.setLEDs(0b00100000 , 0b00000000);
              delay(75);
              module.setLEDs(0b01000000 , 0b00000000);
              delay(75);
              module.setLEDs(0b10000000 , 0b00000000);
              delay(75);
              module.setLEDs(0b00000000 , 0b10000000); // RED LEDS SWEEP
              delay(75);
              module.setLEDs(0b00000000 , 0b01000000);
              delay(75);
              module.setLEDs(0b00000000 , 0b00100000);
              delay(75);
              module.setLEDs(0b00000000 , 0b00010000);
              delay(75);
              module.setLEDs(0b00000000 , 0b00001000);
              delay(75);
              module.setLEDs(0b00000000 , 0b00000100);
              delay(75);
              module.setLEDs(0b00000000 , 0b00000010);
              delay(75);
              module.setLEDs(0b00000000 , 0b00000001);
              delay(75);
              module.setLEDs(0b00000000 , 0b00000000);
              delay(150);
              // END OF SWEEP
              module.setLEDs(0b00000000 , 0b11111111); // ALL RED
              delay(350);
              module.setLEDs(0b11111111 , 0b00000000); // ALL GREEN
              delay(350);
              module.setLEDs(0b00000000 , 0b00000000); // turn off all leds
              // read saved display config
              valButton = EEPROM.read(1020);
              rightButton = valButton;
              valButton = EEPROM.read(1021);
              leftButton = valButton;
              // if EEPROM empty
              if (rightButton == 255 && leftButton == 255){
                leftButton = btnGear;
                rightButton = btnSpeed;
              // show saved display config
              butDisp(leftButton,1); // Moved in one Segment - Archie
              butDisp(rightButton,6);  // Move in one Segment - Archie
              delay(1000);
              module.clear();
            ///////////////////////////////// Main Loop ////////////////////////////////////
            void loop()
              // read input data
              readSerialData();
              // read pressed button
              buttons();
              // update dashboard
              dashboard();
            // Procedure: read serial data
            void readSerialData()
              byte Data[5]={'0','0','0','0','0'};
              // parse the buffer
              if (Serial.available()>4){
                Data[0]=Serial.read();                   // read command
                if (Data[0]=='M'){                       // if rpm data
                  Data[1]=Serial.read();                 // store high byte
                  Data[2]=Serial.read();                 //
                  Data[3]=Serial.read();                 //
                  Data[4]=Serial.read();                 // store low byte
                  rpm = NormalizeData(Data);
                  rpmdata=1;                             // we got new data!
                    Data[0]=Serial.read();               // re-read command
                if (Data[0] == 'S' ){                    // if speed data
                  carspeed = NormalizeData(Data);
                  speeddata=1;                           // we got new data!
                if (Data[0] == 'G' ){                    // if gear data
                  gear = NormalizeData(Data);
                  geardata=1;                            // we got new data!
                if (Data[0] == 'O' ){                    // if oil data
                  oil = NormalizeData(Data);
                  oildata=1;                             // we got new data!
                if (Data[0] == 'W' ){                    // if water data
                  water = NormalizeData(Data);
                  waterdata=1;                           // we got new data!
                if (Data[0] == 'F' ){                    // if fuel data
                  fuel = NormalizeData(Data);
                  fueldata=1;                            // we got new data!
                if (Data[0] == 'L' ){                    // if lap data
                  lap = NormalizeData(Data);
                  lapdata=1;                             // we got new data!
                if (Data[0] == 'P' ){                    // if position data
                  posit = NormalizeData(Data);
                  positiondata=1;                        // we got new data!
                if (Data[0] == 'Z' ){                      // if Shutdown - Output
                  Serial.flush();
                  rpmmax=5000;                             // reset rpmmax
                  module.clear();                          // clear display
                  module.setLEDs(0b00000000 , 0b00000000); // clear leds
              if (Serial.available()>60) Serial.flush();
            // Procedure: display values
            void dashboard()
              if (speeddata == 1) {
                // filter of negative value
                // reported from 65535 to down in some games
                if (carspeed > 50000){                            // reverse velocity in some games are negative value
                  carspeed = 65536 - carspeed;                    // convert positive with 16bit value
                if (leftButton == btnSpeed) {
                  module.setNumberPad(carspeed,2,3);              // displays numerical the speed - Moved in One Segment - Archie.
                if (rightButton == btnSpeed) {
                  module.setNumberPad(carspeed,6,3);              // displays numerical the speed - Moved in One Segment - Archie.
                // if (carspeed == 0){
                //   module.setChars("0",7);
                speeddata=0;
              if (geardata == 1) {
                if (leftButton == btnGear) {
                  offset = 1;     // Moved in one Segment - Archie
                if (rightButton == btnGear) {
                  offset = 6;    // Moved in one Segment - Archie
                if (leftButton == btnGear || rightButton == btnGear) {
                  if (gear >= 1 and gear <10 ){
                    module.setNumber(gear,offset);                        // displays numerical value of the current gear
                  if (gear == 0){
                    module.setChars(neutral,offset);                      // displays the character for neutral
                  if (gear == (65535)){                                   // -1 that reprecents reverse rollover so...
                    module.setChars(reverse,offset);                      // displays the character for reverse
                geardata=0;
              if (rpmdata == 1) {
                if (leftButton == btnRPM) {
                  module.setNumberPad(rpm,3,4);
                if (rightButton == btnRPM) {
                  module.setNumberPad(rpm,7,5);
                // auto set max rpm
                // with filter of negative value
                if (rpm>rpmmax && rpm<50000) {
                  rpmmax=rpm;
                rpmleds = map(rpm,0,rpmmax*1.1,0,9);              // distributes the rpm level to the 8 leds + 1 for shift change
                if (rpmleds==0){
                if (rpmleds==1){
                  module.setLEDs(0b00000001 , 0b00000000 );
                if (rpmleds==2){
                  module.setLEDs(0b00000011 , 0b00000000 );
                if (rpmleds==3){
                  module.setLEDs(0b00000111 , 0b00000000 );
                if (rpmleds==4){
                  module.setLEDs(0b00001111 , 0b00000000);
                if (rpmleds==5){
                  module.setLEDs(0b00011111 , 0b00000000);
                if (rpmleds==6){
                  module.setLEDs(0b00011111 , 0b00100000 );
                if (rpmleds==7){
                  module.setLEDs(0b00011111 , 0b01100000 );
                if (rpmleds==8){
                  module.setLEDs(0b11111111 , 0b1111111111 );
                rpmdata=0;
              if (oildata == 1) {
                if (leftButton == btnOIL) {
                  module.setNumberPad(oil,2,3);
                if (rightButton == btnOIL) {
                  module.setNumberPad(oil,7,3);
                oildata=0;
              if (waterdata == 1) {
                if (leftButton == btnWater) {
                  module.setNumberPad(water,2,3);
                if (rightButton == btnWater) {
                  module.setNumberPad(water,7,3);
                waterdata=0;
              if (fueldata == 1) {
                if (leftButton == btnFuel) {
                  module.setNumberPad(fuel,1,2);
                if (rightButton == btnFuel) {
                  module.setNumberPad(fuel,7,2);
                fueldata=0;
              if (lapdata == 1) {
                if (leftButton == btnLAP) {
                  module.setNumberPad(lap,1,2);
                if (rightButton == btnLAP) {
                  module.setNumberPad(lap,7,2);
                lapdata=0;
              if (positiondata == 1) {
                if (leftButton == btnPosition) {
                  module.setNumberPad(posit,1,2);
                if (rightButton == btnPosition) {
                  module.setNumberPad(posit,7,2);
                positiondata=0;
            // Procedure: read pushed button
            void buttons()
              valButton = module.getButtons();
              if (valButton > 0 && valButton != beforeButton){
                // if second button
                if (millis()-timeButton < 3000){
                  // store slection
                  EEPROM.write(1021,leftButton);
                  butDisp(leftButton,0);
                  delay(300);
                  module.clear();
                // if first button
                if (millis()-timeButton > 3000){
                  module.clear();
                  // store selection
                  EEPROM.write(1020,rightButton);
                  leftButton = 0;
                  butDisp(rightButton,7);
                  delay(300);
                  module.clear();
              beforeButton = valButton;
            // Function: display select function
            void butDisp(int iButton,int off){
                  if (iButton == btnSpeed){
                      module.setChars("S",off);
                  if (iButton == btnGear){
                      module.setChars("G",off);
                  if (iButton == btnRPM){
                      module.setChars("r",off);
                  if (iButton == btnOIL){
                      module.setChars("O",off);
                  if (iButton == btnWater){
                      module.setChars("H",off);
                  if (iButton == btnFuel){
                      module.setChars("F",off);
                  if (iButton == btnLAP){
                      module.setChars("L",off);
                  if (iButton == btnPosition){
                      module.setChars("P",off);
            // Function: convert Hex to Dec
            unsigned int NormalizeData(byte x[5])
            unsigned int result;
            for (int i=1; i<5; i++)
              if (x[i]>47 && x[i]<58 ){   //for xA to xF
                x[i]=x[i]-48;
              if (  x[i]>64 && x[i]<71 ){ //for x0 to x9
                x[i]=x[i]-55;
            result = (x[1]*16*16*16+x[2]*16*16+x[3]*16+x[4]);
            return result;
  4. Archie
    Wollongong, NSW, AU
    3,797Coins
    In AC.. the Gear read out on the TM1638 is One higher than the actual game is displaying, so you have to adjust the Output in GameDash.
    The code for this (enter into the GameDash Pencil Icons for DASH3) is:
    TOHEX
    MATH - 1
    PAD 4 0
    This fails when you go into Reverse (shows Neutral) but I can live with that.. I know the difference between a car going forwards and backwards... :D
  5. Archie
    Wollongong, NSW, AU
    3,797Coins
    This is the part in TM1638.h that needs to change to determine the pins. I used 24-22 on the digital connector of the Arduino as 5V and GND is also accessible from this side.
    Code:
    #define PA2 2 //D24 = DIO
    #define PA1 1 //D23 = CLK
    #define PA0 0 //D22 = STB0
    #define TM_OUT PORTA
    #define TM_IN PINA
    #define TM_DDR DDRA
    #define TM_BIT_STB _BV(PA0)
    #define TM_BIT_CLK _BV(PA1)
    #define TM_BIT_DAT _BV(PA2)
  6. maphf60
    maphf60 New Member
    - 507Coins
    Hello everyone,
    I introduce myself, I am maphf60 and I live north of Paris, I am retired and I am passionate about motor racing.
    For several months I have begun construction of a simulator 2 DOFs.
    I use engines windscreen wipers 24v, IBT-2 H-bridge and an Arduino Nano. The steering wheel is a Thrustmaster T300 RS + 2 TH8 and pedal parts.
    To improve overall, I would add a display Gear (gear ratio), Speed (speed) and rpm (revolutions per minute engine). For this I use TM1638 + Arduino Nano.
  7. maphf60
    maphf60 New Member
    - 507Coins
    gameDash: M <dash2> S <dash1> G <Dash3> 20 ms
    Z00 (output)
    Dash1: MATH * 3.6 TOHEX PAD 4 0
    Dash2: TOHEX PAD 4 0
    Dash3: MATH - 1 4 0 TOHEX PAD
    Assetto Corsa and rfactor 2: Gear and rpm are displayed correctly but never Speed.
    Dirt Rally Gear only appears
    Project Cars: NOTHING
    It would be nice if someone could give me the solution to my problems.
    Thank you in advance hello.
  8. maphf60
    maphf60 New Member
    - 507Coins
    Hello, Archie.
    How to driver 2 modules TM1638.
    What modifications should be made in the TM1638 library.
    Thanks and greetings.
  9. Archie
    Wollongong, NSW, AU
    3,797Coins
    @maphf60 - Hello! I'm sorry, it's been well over 18 months since I last played with Gamedash and the TM1638. I've forgotten most of it and I ended up taking all that stuff off my Sim when I got into VR.
    Can't help :(
  10. maphf60
    maphf60 New Member
    - 507Coins
    Hello Archie is still maphf60 with its problem TM1638 library.
    Library: TM1638_v1.02.
    What needs to be done to modify an arduino library?
    You know another person who could help me.
    Acknowledgments and sincere greetings
    153,866Coins
    +11,154 / 57 / -2
  12. maphf60
    maphf60 New Member
    - 507Coins
    Thanks a lot to Archie and Noorbeast for your help
    I will contact Soraz who is still working on TM1638
    Salutations to all
  13. Peter Lane
    Peter Lane New Member
    155Coins
    Great looking project! I hope I can get mine looking as good.
    Sorry for the stupid question but, if I was to copy the code below and paste into Arduino sketch, would this work for me. I am also using a Tm1638 and currently I am using an example from Joao Ubaldo to run in rfactor.
