RacingMat
Arduino code: 4DOF and 1 pin direction Hbridge 3.2
source code
  1. RacingMat
    Please find inside the .ino file, the Arduino code needed to run a 3DOF or 4DOF simulator.
    It's written to work with Hbridge having only 1 pin for direction.
    such as Pololu 755 single Hbridge driver board (40 $ per motor)
    5.5 to 30 V and continuous 15 A without a heat sink.
    http://www.pololu.com/catalog/product/755
    This file is a text file that can be loaded in Arduino IDE
    or simply opened with Notepad for viewing purpose.
    A tutorial is provided to implement the code and setup your simulator with this code: 4DOF code implementation
    about Arduino: http://www.arduino.cc
    Pololu 755 only needs 1 PWM pin and 1 Dir pin to drive the motor
    So one Arduino UNO could drive up to 6 motors!!
    and even more if using SoftPWM tweak... (need to be tested)
    https://code.google.com/p/rogue-code/wiki/SoftPWMLibraryDocumentation
    Mazava likes this.
  1. Value below 16 bug corrected
  2. minor update
