vthinsel
Assetto Corsa UDP (Consoles) - Manual plugin start 1.0
Assetto Corsa UDP plugin for consoles
  1. vthinsel
    Assetto Corsa Plugin Installation instructions
    - Install the plugin as usual
    - Open the zip file and copy manually the files ACPlugin.xml and AssettoCorsa_VB_UDP_Receiver.exe to the plugin location folder which is C:\Users\<your username>\AppData\Local\SimTools\GamePlugins
    - Edit the ACPlugin.xml file : change the IP address to match the IP address of your console.
    Use the plugin as a regular UDP plugin
    This plugin has just heave/sway/surge as unfortunately there is nothing we can use to have roll/pitch/yaw
    GameDash basic data is also supported
    eaorobbie likes this.
  1. santanadany
    santanadany
    Version: 1.0
    Great ! for Playstation4
