value1
Automobilista 2 Plugin 2020-04-05
SimTools game plugin for Automobilista 2
  1. value1
    Genre
    : Sim racing
    Motion Data:
    This plugin provides pitch, roll, yaw , surge, sway & heave and Traction Loss
    GameVibe:
    Supported (RPM, Gear Shift, Collision L/R, Collision F/B, Road Detail, Chassis, Turbulence)
    Dash Data:
    Speed [km/h], RPM, Gear (-1 = Reverse), Game State, Player, Car, Class, Track, Car Flags, Oil Temp [°C], Oil Pressure [kPa], WaterTemp [°C], Water Pressure [KPa], Fuel Pressure [KPa], Fuel Level, Fuel Capacity, max RPM, Ambient Temperature, Highest Flag Colour, Lap valid
    Author: value1, yobuddy
    How to activate AMS2 telemetry output:
    ❉ In steam add the launch option "-ui:pcars" this will allow you to enable UDP and SharedMemory. Its using the exact same data output as PCars2 for shared memory.
    ❉ once you have enabled shared memory in the system setting using the pcars ui you can then delete -ui: pcars from the launch options in steam to return to the AMS2 ui
    ❉ Also the max min settings in the Tuning Center.
    Tripaki, Onaflyer, CYD and 6 others like this.
  1. MasterYoda
    MasterYoda
    Version: 2020-04-05
    Works great, thanks!
  2. Ruben Bragado
    Ruben Bragado
    Version: 2020-04-05
    Good job!
