This PERL script has helped me capture a ton of Data for Video Ride Creator, Hope it Helps you too!
Requirements:
ActivePERL (https://www.activestate.com/activeperl)
Window 7 (Only OS I have Tested, to date)
SimTools
DataCapture.zip (Download Now)
Instructions:
Once you have ActivePERL Installed and SimTools is interpreting the game data to your liking
Extract DataCapture.zip (Should have a datacapture.bat and script.pl file inside)
SimTools Interfacing Settings
Interface Type = "NETWORK"
IP = "127.0.0.1"
Port = "2424"
OutPut Bit = "8"
OutPut Type = "Decimal"
Startup - Output = "start" -ms
Interface - Output = "<Axis1a> <Axis2a> <Axis3a> <Axis4a> <Axis5a> <Axis6a>" 10ms
ShutDown -- Output = "stop" -ms
SAVE
SimTools Axis Assignments
**VERY IMPORTANT TO DEFINE ALL AXISES for Video Ride Creator
Define Each Axis (The Axis order above is the standard order in which most programs read data columns)
SAVE!
Start the Game of your Choosing
Verify SimTools is Reading Game (Game Manager should say "Game Running")
Run "datacapture.bat" (double click to run)
Once you captured the game YOU MUST TURN OFF the GAME MANAGER (By clicking the ON button) - This will finalize the captureData.txt file (Below)
In the SAME location as "datacapture.bat" look for a new file generated named "capturedData.txt"
This is the captured game data, ENJOY!
Capture Live Telemetry BETA 1.0
Script written in PERL to Capture Live Game Data being Outputted by Simtools
