Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.1.0.2 pointer update
  1. Wagnard
    Genre: Space Simulator
    This plugin provides pitch, roll, yaw,speed, surge, sway and heave acceleration (SPACESHIP)
    This plugin provides pitch, roll and accelerations for yaw, surge, sway and heave. also Extra 1 Roll and Extra 2 Pitch (SRV)
    Features:
    -External configuration file (XML) for updating the pointer and other settings.
    -GameVibe (Turbulence, Road Detail, Collision L/R & F/B)
    The plugin is configurable via an XML file (within the plugin folder) allowing you to:
    -Manually change the pointer without recompiling the plugin
    -Option to change the SRV DOF to reverse
    -Changing the % of force
    -Option to change the SRV Roll & Pitch from the Extra1-2 to the normal Roll / Pitch.
    This plugin works with the current version of Elite Dangerous: Horizons Fleet Carriers Patch 4
    Special instructions:
    -If you are updating from a previous working version of this plugin, there is no need to patch again, just use the SimTools plugin updater.
    -After patching, have a look at the XML to configure the forces to your desired values.
    -If GameManager crash on game launch, it probably mean you have an outdated wow64ext.dll (9kb) in the plugin directory.
    I advise you replace it with the one located on your simtools installation directory, it should be around 700kb in size.
    Author: Wagnard
    Based on the work of : value1, SilentChill
    tak98, Vitalius, HarryX61 and 14 others like this.
  1. chaoskahn13
    chaoskahn13
    Version: Odyssey update 15.01
    Thanks so much for keeping this updated!
  2. DragonX
    DragonX
    Version: Odyssey update 14
    great work
  3. Nguyen Huy
    Nguyen Huy
    Version: Odyssey Update 9
    Great!
  4. noe
    noe
    Version: Odyssey Update 7
    top plugin !!
