value1
Forza Motorsport 7 Plugin 2.0.0.0
Plugin for Forza Motorsport 7
  1. value1
    Genre: Arcade Racing
    This plugin provides pitch, roll, yaw and surge, sway, heave acceleration and traction loss.
    Speed, RPM
    GameVibe:
    Supported
    Author: value1
    Important note:
    Because Forza Motorsport 7 UDP output does not support localhost, you have to do some tweaks on your router.
    Typically there is a "port forwarding" possibility in your router - maybe under Advanced Settings / Additional Features /etc.
    • Specify a sensible name for the rule (e.g. Forza7)
    • Enter the IP address of the PC where FM7 and SimTools run.
    You can check this address by <ÿ>-R – cmd – ipconfig <ENTER>
    Under IPv4 Address you will see the address of your PC.
    • Specify under external port 4122
    • Specify under internal port 4123
    (• select UDP Protocol)
    In the game under [Options] – [HUD] you select [DATA OUT] ON, set for [DATA OUT IP ADDRESS] your internet IP address (see www.myipaddress.com) and [DATA OUT IP PORT] 4122
    Important: Press <ENTER> now, not <ESC>!
    Note: Your PC's address might change from time to time as well as your internet IP address. So check both addresses, in case you get no data after a few days!
    Kudos to @Sarge, @Mu-KwangKim, @junhyuk Ahn for your great help!!!
  1. yobuddy
    Version: 2.0.0.0
    Sweet!!
  2. Mu-KwangKim
    Mu-KwangKim
    Version: 2.0.0.0
    Good Work!
