Genre: Arcade Racing
This plugin provides pitch, roll, yaw and surge, sway, heave acceleration and traction loss.
Speed, RPM
GameVibe:
Supported
Author: value1
Important note:
Because Forza Motorsport 7 UDP output does not support localhost, you have to do some tweaks on your router.
Typically there is a "port forwarding" possibility in your router - maybe under Advanced Settings / Additional Features /etc.
• Specify a sensible name for the rule (e.g. Forza7)
• Enter the IP address of the PC where FM7 and SimTools run.
You can check this address by <ÿ>-R – cmd – ipconfig <ENTER>
Under IPv4 Address you will see the address of your PC.
• Specify under external port 4122
• Specify under internal port 4123
(• select UDP Protocol)
In the game under [Options] – [HUD] you select [DATA OUT] ON, set for [DATA OUT IP ADDRESS] your internet IP address (see www.myipaddress.com) and [DATA OUT IP PORT] 4122
Important: Press <ENTER> now, not <ESC>!
Note: Your PC's address might change from time to time as well as your internet IP address. So check both addresses, in case you get no data after a few days!
Kudos to @Sarge, @Mu-KwangKim, @junhyuk Ahn for your great help!!!
