This plugin reads the axis and buttons on a joystick and outputs these values in SimTools.
It has been tested with a Microsoft Xbox 360™Wireless Controller. Other joysticks will work too.
Genre: Tools
Surge, sway, heave, pitch, roll and yaw are fed with the axis positions of the joystick. Extra1 indicates the buttons pressed. Extra2 indicates the number of buttons pressed. Extra 3 finally indicates the position of the digital direction pad.
How to use:
Run GameManager in Admin mode.
Select the "game" Joypad.
Patch by selecting the installation directory of SimTools.
The patch installs a program "SimTools_Joystick.exe" and "SimTools_Joystick_Recorder.exe". These programs do nothing than trigger SimTools to read the Joystick values.
Run GameEngine & GameEngine.
Run SimTools_Joystick.exe or – if you watn to record the data – run SimTools_Joystick_Recorder.exe.
Play with your joystick and observe the values in TuningCenter.
You can also run a simulation/game in parallel. However certain games (like Codemasters and LFS) must be unpatched first.
Author: value1
- Update for SimTools V2 Jan 7, 2017
- Allows the selection of the Joystick Jan 14, 2015
- Including data recording Jan 11, 2015
