Icy7CE
Sensor UDP Plugin (Testing Tool) 1.0.1.0
SimTools Plugin for Sensor UDP
  1. Icy7CE
    This plugin is actually for a testing tool, not a game. It allows an Android device to be used as a virtual vehicle by reading data from the app Sensor UDP. Moving and rotating the device causes the simulator to move in a corresponding manner.
    Steps for use:
    1. Download and install the plugin in the usual way, using PluginUpdater.
    2. Extract the file SensorUDP_Connect.exe from the downloaded zip file, and run this executable. This acts as the "game" running on the computer.
    3. Download and install Sensor UDP on an Android device. Run this app and enable acceleration and orientation data, and enter the IP address and port number displayed in SensorUDP_Connect.exe. The IP should be the computer's internal IP address (e.g. 192.168...) and the port should be 20777.
    4. Open GameManager and GameEngine on the computer and push the Send Data button in the app. Data should now be transmitted from the app to SensorUDP_Connect.exe, which then transmits it to SimTools.
    Motion data: Roll, pitch, yaw, heave, sway, surge
    Author: Icy7CE
    ihed24, Dirty and eightbit like this.
