Some Hbridge can accept up to 20KHz PWM:
because these ultrasonic frequencies are inaudible, you don't hear anymore the humming sound of your motor at low speed.
This code allow the Arduino UNO/Nano to increase its standard poor 490Hz PWM up to 20kHz![]()
The code has to be adapted if you're using MEGA board for instance.
Check the datasheet of your Hbridge if it can accept ultrasonic PWM.
- For example VNH2SP30 chip can do this (but is limited to 16V) like Motomonster.
- Unfortunatly, 36V VNH3SP30 chip cannot reach 20kHz PWM
Hear the difference:
Some more information brought by Pipis2015
thanks for this feedback !
If you want to use Pololu_Dual_VNH5019 stacked onto the Arduino:
you only need to change
ultrasonic code:
into this:Code:int inApin[2] = { 7, 4}; // INA: Clockwise input int inBpin[2] = { 8, 5}; // INB: Counter-clockwise input
Code:int inApin[2] = { 2, 7}; // INA: Clockwise input int inBpin[2] = { 4, 8}; // INB: Counter-clockwise input
