value1
X-Plane V11 plugin 2019-09-01
SimTools game plugin for X-Plane V11
  1. value1
    Genre
    : Flight simulation
    This plugin provides pitch, roll, yaw and surge, sway, heave acceleration.
    Extra1, Extra2 and Extra3 are pitch/sec, roll/sec, yaw/sec, which make more sense in a fligth simulation.
    (Earth gravitation is subtraced from heave acceleration.)
    Speed, RPM (engine, propeller).
    SimVibe:
    Supported
    Author: value1
    Notes on installation:
    • If you had installed the old X-Plane V10 plugin, you might need to remove all xplane* files from C:\Users\user\AppData\Local\SimTools\
    • In the settings menu of X-Plane (upper top right corner) upload_2019-9-1_16-10-12.png check at least index 135, Motion platform stats – Network via UDP, IP address 127.0.0.1 and Port 4123.
    For SimDash and Simvibe also check index 3 (Speeds), 17 (Pitch, roll & headings), 37 (Engine RPM) and 38 (Propeller RPM). Other datasets can be checked additionally, we don't care.
    XaSeAl, Airbas72 and hexpod like this.
  1. alfsin
    alfsin
    Version: 2019-09-01
    gracias por tu aporte
