Sequential gearbox homemade
Discussion in 'DIY peripherals' started by -kevin-, May 17, 2015.
  1. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    This sequential gearbox and was made with the following materials:
    needed:
    2 iron plates of 15x10 cm with a flap bent 1cm
    a threaded rod M8
    4 springs from 5cm
    2 microswitch
    8 extensions for threaded rods M8
    a lever recovered from 30cm
    a knob Sparco
    here are some pictures is a video of the operation is unfortunately the only video I
    not to add external devices, I connected the wires to the sequential gearbox g27
    From the photos you can see the various details of construction
    Video
    • Like Like x 10
    • Winner Winner x 3
    153,728Coins
    Great job there on the shifter @-kevin-, another quality addition to the growing list of DIY peripherals :thumbs
  3. -kevin-
    128Coins
    Thanks noorbeast ;) since there are also I add the handbrake :)
  4. RacingMat
    21,081Coins
    looks really nice! :)
    Could you please describe the mecanism: what part is articulated or fixed?
    I would be great if you could draw a simple sketch!
  5. zigzag49
    zigzag49 Active Member
    726Coins
    Merci pour le partage , très beau séquentiel et frein a main .
    Thank you for sharing, very nice sequential and handbrake.;)
  6. -kevin-
    128Coins
    Thank you very much @RacingMat :thumbs
    The gearbox is simple and economical
    I ask my friend if I billo creates a 3D drawing and then share it here, because I'm not good with the drawings.:(
    @zigzag49 is a pleasure, thanks for the positive comment :thumbs
  7. Quertreiber
    Quertreiber New Member
    Eppingen-Germany
    361Coins
    I soldered my sequential shifter to the G27 paddles, too. It is a bit of work but it is absolutely worth it.
  8. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Superb :thumbs
    I would do well my shifter with this method :)
  9. Cluclu
    Cluclu Member
    443Coins
    Good job !
  10. fartface
    fartface New Member
    Canada
    238Coins
    This is an awesome looking setup, well done!
  11. -kevin-
    128Coins
    Thank you all.
  12. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    magnifique !!! great job
  13. Dmraf
    Dmraf New Member
    Ufa, Republic Of Bashkortostan, Russia
    174Coins
    Hello. I have a problem with the gear shift. I have a fly speed. I want to connect my Sequential gearbox to the steering wheel G 27. Do you think it will help me? Sorry for my English
  14. rattler
    rattler
    Yes you could, I remember seeing a document ages ago. I think it was a matter of opening the G27 shifter and re-soldering wires off 2 switch points and then solder them to your switches in your sequential shifter
  15. Dmraf
    Dmraf New Member
    174Coins
    Thank you for your reply.
