4DOF Servo electrical engineering and Arduino conjunction.Please help.
Discussion in 'DIY Motion Simulator Projects' started by ymh, Feb 25, 2016.
  1. ymh
    ymh Goal 4 dof
    China
    154Coins
    DC motor
    A complete set of four-axis equipment.
    Panasonic A4 series 750W servo motor
    I want to know how the servo motor controller feeds back the position signal to the Arduino board.
    The underneath is a servo electrical engineering to connect a people's diagram.
    The following is the interface diagram of the servo motor.
      66.5 KB
      1,701
  2. RioSmith
    RioSmith New Member
    CHINA
    237Coins
    Why feed back the encoder signal to Ard? Just give the driver a pulse signal.
  3. ymh
    ymh Goal 4 dof
    China
    154Coins
    DC motor
    The forum code I download now is designed to compare the direction and angle of the motor by connecting a potentiometer to the 5V of the Arduino board.
    If you use a servo controller now, you don't want to use a potentiometer to connect to the servo motor and then feed it back to the Arduino board.
    The forum estimates that there is a code for directly outputting the pulse signal to the driver as you mentioned. But due to my bad English, I don’t know that it is :(
    Please also help find it~Thank you~
  4. RioSmith
    RioSmith New Member
    CHINA
    237Coins
    Sorry,I don't use the Arduino board to control,so i don't learn the code.Maybe i will meet this in the further and i will touch you then.
  5. ymh
    ymh Goal 4 dof
    China
    154Coins
    DC motor
    SCN electric cylinder do you use?
    Do you use SCN5?
    Or some other mode?
    Or what other mode?
