Arduino models
Discussion in 'Electronic and hardware generally' started by Guilherme Correia, Mar 7, 2016.
  1. Guilherme Correia
    Guilherme Correia New Member
    165Coins
    Good afternoon, here ( Brazil ) , meeting easily two types of Arduino , the uno r3 and leonard replacing the door COM, with a plug and play, I wonder if it changes something in the command using the leonard arduino or if it is possible to use uno r3 ?
    Boa tarde, aqui (Brasil), encontro facilmente dois tipos de arduino, o uno r3 e o leonard que substitui a porta com por plug and play, gostaria de saber se muda algo no comando se utilizar o arduino leonard ou se é possivel usar o uno r3?
  2. Pit
    30,510Coins
    if you mean you would like to use any sketches either with the leonard or the r3, you can use both.
  3. Guilherme Correia
    165Coins
    ok, thanks...
    by google translator must have been strange phrase, the words.. thanks
  4. meo_udon
    meo_udon New Member
    691Coins
    If you need to make custom USB device (etc. PANEL) Leonado can. And Leonado more PWM pins than UNO.
