Showroom 3070W 6DOF Seat Mover (WIP Surge_Sway table)
Discussion in 'DIY Motion Simulator Projects' started by Pit, Mar 5, 2014.
  1. ymh
    ymh Goal 4 dof
    China
    154Coins
    DC motor
    Before and after the two axes around mobile, produces the feeling that the centrifugal force, two axis to realize slope, rough. Is that so? There are two do you use?
  2. Pit
    30,498Coins
    You mean the surge and sway tables? Each of these axis are independently moving and indeed they simulate longitudinal and lateral forces.
  3. eaorobbie
    20,488Coins
    Good to see its still alive and ya enjoying v2 yet.
    Quick question , why do you persist to use more than 100% of axis.
  4. Pit
    30,498Coins
    The "problem" here is the high value in the tuning center which is needed because of the surge table. As a consequence of this I have to use a very high percentage of the surge axis of the seat to get some noticeable moving. I suggested yobuddy to implement two independent tuning centers for Axis Assignment a and b but probably this is not really recommended. Heave is powered by two systems, same issue here, I have to play with one tuning center value so I have to adjust the axis percentage to get the best of both.
  5. ymh
    ymh Goal 4 dof
    China
    154Coins
    DC motor
    Carefully read your image details, finally see ~ is a very good design.:thumbs
  6. eaorobbie
    20,488Coins
    Ok working filters should be able to fix this issue now , sorry to sound rude man , just couldn't work out why , I have helped many members on surge tables specially and few on traction loss tables, yes agree there is a fine balance to be found in values without using filters.
    I too don't feel extra tuning centre values are needed either , with tuning it's achievable, with working filters its so much more adjustable. My first thoughts was more values but from nearly 2 years of use, tuning is the key.
    Btw Wow! its a beast now man , Well done mate.
  7. RacingMat
    21,059Coins
    @Pit: could you please tell us how to source the bicycle part you're using as a lever? keyword or URL link? as cannot find it
    I like it and I'd like to do the same for a 20mm diameter shaft :)
  8. Pit
    30,498Coins
  9. Pit
    30,498Coins
    BTW I will kick out the winch under the seat by replacing it with one of the 24V motors which have been left. This winch was a very cheap one (50$) and the gears are so badly done that I cannot believe that it will pull a car or boat...
  10. RacingMat
    21,059Coins
  11. Pit
    30,498Coins
    New video testing SimTools2:
    PS: I was trying a washout filter on Extra1, so please overlook this.
    • Like Like x 8
    • Winner Winner x 7
  12. value1
    15,079Coins
    Just stunning!
    • Agree Agree x 4
  13. Federico 80
    Federico 80 New Member
    436Coins
    Very nice Sim! Congratulations!
  14. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Not sure I can imagine the feeling of going forward and sideways. Forward/backwards for surge I get, the lateral movement I dont. Can you provide any idea?
  15. Pit
    30,498Coins
    If you could upload a video showing game/car behavior and your rig in action probably it would be easier to determine what your have in mind.
    PS_ on my rails I feel well the lateral forces, furthermore I use the seat mover too to incrase the effect. So I have two axis working on this.
  16. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Maybe what I meant wasnt clear. I have thought about adding the surge motion where the whole rig moves forward. As for your lateral movement side to side, do you feel thats worth the space and the investment? Havent seen anyone take that approach before.
  17. Pit
    30,498Coins
    agree, my idea which is not new comes from the toyota simulator. There are some F1 simulator as well using rails to simulate some g-forces. My handicap is the limited space, I should use 3 meters or more to simulate the forces, but I have only 1m at least. The lateral forces are better to reproduce than the longitudinal forces, because the acceleration is way longer than the curve radius.
    • Informative Informative x 3
  18. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Cool, thanks for that. Been looking to either add surge and traction loss or a complete new build of 6dof. If you had to choose which would you go with knowing how your current setup feels?
  19. Pit
    30,498Coins
    racing simulator = I would do the same again and probably I would optimize my rig once upon a time when I have more space - lol - Flight simulator: 6 DOF for sure.
  20. SeatTime
    Nothing against your sim, but I keep reading on this site that 6DOF Stewart platforms are no good for car racing sims and though so myself until I finished building my own. I expect it was due to watching some of the large AC driven platforms, which are purposely de-tuned to save the gearbox and other components due to the large mass being moved. Believe me, a light weight/low mass ball screw driven 6DOF is hard to beat and is only limited by the resolution of the data feed to it. With the right input I could play a tune on my actuators :).
