NEW 6DOF rig design and scale model
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Alita588, Feb 16, 2016.
  1. Alita588
    Alita588
    I Just finished making a scale model of the 6DOF rig I'm planing on building. I wanted something physical so i could work out the geometry and make sure their are no major problems. Im intending on using a VR headset for both driving sims, flight sims and elite dangerous. I will probably be using 200w - 300w, 24v DC motors wit ha 1:50 gear reduction. Im pretty sure the lever arms I have in the model are longer then what i can get away with but thats easy enough to adjust.
    What do you guys think?
    Do you see any problems with the design i can improve on?
    • Like Like x 8
  2. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Your scale model is already superb, very good precision work:thumbs
  3. Alita588
    Alita588
    Thank you :D
  4. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Beau projet, Des moto-réducteurs de 250w peuvent faire l'affaire si vous disposer d'environ 30 Nm en sortie.
    Beautiful project, 250w Some of gearmotors can do the trick if you have about 30 Nm output.
  5. Alita588
    Alita588
    Thanks, yes that was more or less what I was calculating. Still debating if I want more movement or faster movement. From want I understand from other posts that VR doesn't take kindly to vibration or sharp movement. I will also probably add 3 pneumatic cylinders to each set of frame posts to help lift the platform so the motors don't have to work as hard. Thoughts?
    • Disagree Disagree x 1
  6. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Pour moi, des ressorts en acier seront beaucoup plus efficaces, moins esthétiques et plus encombrant aussi...
    For me, steel springs will be much more effective, less aesthetic and more cumbersome as ...
  7. Alita588
    Alita588
    Interesting, I'll think about that more then.
  8. wannabeaflyer2
    london uk
    8,350Coins
    Hi @Alita588 Aha another 3d printer strikes again LOL . Don't you just love this technology , Very nice model , was that your own design or were you able to download the Models from somewhere ( ref the seat . Race wheel , Motors etc Nice work and looks great as well :)
  9. Alita588
    Alita588
    Thanks, The rig is my own design based on all the research I did on this and other forums. It borrows from many designs. I discovered recently that it's not unique at all but was a good mental exercise non the less.
    The 3D printer is very usful for this project as you can see. The seat was someone else's model but all the other parts I modeled. I couldn't find good models that where printable so I made my own. If anyone wants them it be happy to share them.
  10. wannabeaflyer2
    london uk
    8,350Coins
    lol count me in . I'm at the print anything I can on my machine stage at the moment so the more sim related parts the better . a saw Race seat model somewhere so just need to find it again .. so Hell Yeah :) if you have the models i'll print em just for the hell of it Cheers #
    153,848Coins
    +11,152 / 57 / -2
    @SilentChill use gas struts to take some of the load on his DC powered 6DOF rig: http://www.xsimulator.net/community...tors-mms-and-arduinos.6948/page-21#post-94241
  12. Alita588
    Alita588
    Thanks for the link to @SilentChill build. I have referenced it a lot as i designed mine. I think my design most closely resembles @SeatTime. It seams gas pistons are the ideal off-the-shelf solution. Rigging up springs with the right compression ration seams much more complicated in comparison.
  13. Alita588
    Alita588
    sketch files ok?
  14. Alita588
    Alita588
    Here is some of the SketchUp models I made for this project. It includes the Thrustmaster HOTAS Warthog controllers, Thrustmaster T300 wheel and T3PA-Pro foot peddles. I also included a motor model and lever arm. The motor is based on the gross measurements of the 320W industrial motor found on Motion Dynamics website. I choose this mainly because it was pretty large and I wanted to make sure I had space for everything. In reality I will might use something smaller.
    • Useful Useful x 2
  15. Alita588
    Alita588
    Phase 2 of my build included servo motors used to control each axis. I successful modified and installed the Arduino code needed to use the data for SimTool. I also adjusted SimTools DOF for all 6 axis of control. Now I just need to find some plugins that work with the games i have. Unfortunately the Elite Dangerous plugin is broken. :(
    How do I find up to date plugins?
  16. Historiker
    9,205Coins
    • Friendly Friendly x 2
  17. Alita588
    Alita588
  18. Alita588
    Alita588
    @Historiker WOW, thank you for the coins! :) Thats nice of you.
  19. Historiker
    9,205Coins
    Sorry, I thought you were asking about plugins other than ED.
  20. phisado
    phisado New Member
    bangkok
    302Coins
    :thumbs
