Showroom 6DOF Build (Bodine Motors, Sabertooth, FlyPT Mover)
Discussion in 'DIY Motion Simulator Projects' started by BondeX, Mar 10, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    I use the 360degree pots with reduction 2.24:1. Others with 1:1 ratio (attached directly without gears) seem to prefer 180 degree pots. so you may want to give thought to how you will be mounting these to the motors. @SilentChill is correct order a few extra monsters. At 7.50 each it will be worth it rather than waiting for more. Trust me when I say it sucks waiting for china post when all you need is a few components.
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    Also I notice the threaded rod, I started with it and bent it. ended up going with small square tubing with proper sized bolts welded to the ends. less expensive, stronger and lighter as the tubing is hollow. Although the weight difference is so small it really doesnt matter.
    • Agree Agree x 3
  3. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Guys, thanks for the help, I will get the 180 pots.
    OK will order MMs, Ards and ball joints today.
    @bruce stephen, what size threaded rods were you using that got bent?
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    m12, but now i have hardened bolts as ends not soft steel.
  5. Historiker
    9,208Coins
  6. BondeX
    EE
    Michigan, USA
    1,501Coins
    @bruce stephen , @Historiker , thanks for the advice bUT I need to switch gears towards motors as I am able to get 6 bodine motors for 250$ less than pgsaw.
    I think I am gonna order them, please stop me if you guys feel I will get better performance out of pgsaw.
  7. BondeX
    EE
    Michigan, USA
    1,501Coins
    Hey @bruce stephen, you mentioned in one of the posts that your bodine motors did trip your 50A power supply? Is that right? Are you using two full bridge MMs per motor than for 30A continuous and 60A peak?
  8. BondeX
    EE
    Michigan, USA
    1,501Coins
    SIX BODINE MOTORS ORDERED YAAAAAAAAAAAAYYYYYYYYYYYYY :p This motor picking/ordering is freaking stressful :mad:
  9. Nick Moxley
    Now lets hope they deal with the weight of the rig + yourself. Your Still in Untested waters fyi.
  10. BondeX
    EE
    Michigan, USA
    1,501Coins
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    For my 2 dof I run 2 50 amp psu's wired parallel. I have one full bridge per motor. But This is a well balanced 2 dof so it does not draw as much power while operating IMO. I would recommend following @SilentChill and go with 2motos per motor. Wait, What are the specs for the motors you acquired are they the same as the ones I linked to above?
  12. BondeX
    EE
    Michigan, USA
    1,501Coins
    @bruce stephen they are the same motors as you. 23A max they say but we know better that stall current can be a lot higher. Did you have two motors on one 50A PS at first?
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
  14. BondeX
    EE
    Michigan, USA
    1,501Coins
    Where do I get those black terminals that @SilentChill is using on those MMs, the ones that the wire goes into?
    @bruce stephen those heatsinks are more expensive. Cant I just put any heat on and then blow a separate fan them heatsinks?
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    I was going to do as @SilentChill did. Two motos per motor.
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
  17. BondeX
    EE
    Michigan, USA
    1,501Coins
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    8amps@250volts....
    They will be ok on 12 volt.
    These are what I used and haven't had any problems.
  19. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    Be careful when using terminals.
    If you can't find the proper specs then solder the wires directly on the board.
    8 amps at 250 volts may be 2000 Watts but this doesn't mean that they can handle more amps at lower volts.
    That's why they are rated with Amps and not with Watts. All wires are amp rated.
    An easy way to understand it is this:
    Volts=the speed that electrons traveling in a wire.
    Amps is the density of electrons traveling in a wire.
    Density(amps) heats up more than speed(volts).
    That's why when electric power is to travel over long distances it is converted to high voltage rather than high amperage.
  20. SilentChill
    20,595Coins
    I used the cheapest ones I could find, remember you are spreading the load through 8 x connections per motor so there will be no issues with over current in the terminals I never had any, its the brushes that get hot.
