Project 2Dof
Discussion in 'DIY Motion Simulator Projects' started by Bordiin, Sep 30, 2015.
  1. Bordiin
    Bordiin Active Member
    Brazil
    159Coins
  2. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    So I'm think on buiding one "line actuador" home made with 12v motor 12n.m 14.000RPM maybe can be good
    153,770Coins
    +11,149 / 57 / -2
  4. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
  5. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    14000 rpm is very fast and all changes of direction may damage the motor...
  6. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    Yes I agree with you but , this the max speed we can put more lower speed by controllers and I find some thread bar to actuators and have mani size diferent to improve the motor reduction, for me in special is how I can control the "feetback position ".
  7. Bordiin
    Brazil
    159Coins
    My simulator to no limits, almost ready.
    153,770Coins
    +11,149 / 57 / -2
    You have a lot of torsional twist at the pivot joint and need a panhard style rod between the seat and base frame to control it, as you are loosing a significant amount of motion fidelity: https://en.wikipedia.org/wiki/Panhard_rod
  9. Bordiin
    Brazil
    159Coins
    @noorbeast something like this? and using the M8 tip rod.
    if have some thread that explain send me. Thanks
    153,770Coins
    +11,149 / 57 / -2
    Something like this, with a rose joint either ends, fixed to the seat frame and then attached to a bracket on the base. What it will do is stop the seat rotating.
  11. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Yeh your motors might go snap city too if you dont remedy that. What are you using as a pivot?
  12. Nick Moxley
    A VERY thin diameter steering U joint from the looks of it.....I would swap that out for something a little bigger.
  13. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Yeh the size is a little on the small side. Im just curious how its twisting so much. Even if its a steering u joint it shouldn't twist so much. I wonder if its loose and its slipping?
  14. Nick Moxley
    I would also venture to say there's a loose bolt here or there.
  15. Bordiin
    Brazil
    159Coins
    I will make the change that @noorbeast suggest and send pictures.
  16. Nick Moxley
    Check the U joint first, If that's the issue, you need to fix that problem, Not add bandaids to it.
  17. Bordiin
    Brazil
    159Coins
    Ok @Nick Moxley , Look my U joint, it's small. Maybe i need building one like the Wanegain.
  18. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Looks like you've welded it on at an angle,,, or is that just the angle of the picture?
  19. Bordiin
    Brazil
    159Coins
    @stevemontun it's because of the motors positions
  20. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    You shouold still not be able to hold that in your hand and twist it. Do you have slop in your bolts holding it together?
