How to choose potentiometer
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by DonCorleonez, Mar 15, 2016.
  1. DonCorleonez
    DonCorleonez Member
    195Coins
    Hi all,
    Been through several projects, until i came up with this question, how to choose potentiometer?180/360 rotation? let say i am using wiper motor, what kinds of condition i should choose 180/360?
    regards
  2. RacingMat
    21,059Coins
    About potentiometers, here are some clues:
    - 10 kOhm (not less, not more)
    - linear variation (not logarithmic)
    - 360° are not truely "360° electrically": the track is only 340° max
    - some may have mechanical stops: it's safer for the pot itself if it has no stops
    but it's not an issue really
    As the motors are used on a range from 120° to 180° usually
    ► 180° pot is fine if you want simple and direct connection between pot and motor (rigid coupling)
    ► 360° can be used in conjunction with gears to increase resolution BUT it's more complex mechanically and if gears have some gap, you loose the benefits...
    • Informative Informative x 3
  3. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Also recommended is to use a hall effect position sensor, also called a non-contact position sensor or non-contact potentiometer. Because the position sensing is magnetic instead of using a physical wiper rubbing on a resistor, they last much longer and have a smoother response. Also they generally don't have a stop to crash into.
    • Agree Agree x 3
  4. ferslash
    ferslash Active Member
    4,798Coins
    guys please move this tread to the Q&A (since it is clear short an explicative)
    fer :D
    152,571Coins
    +11,087 / 56 / -2
    152,571Coins
    +11,087 / 56 / -2
    • Useful Useful x 2
  7. DonCorleonez
    DonCorleonez Member
    195Coins
  8. cgodwin
    Engineer
    Eugene, Oregon
    2,478Coins
  9. RacingMat
    21,059Coins
    Hall effect pots are interesting indeed!
    (apart from the price)
    but just for the record, they are not perfect:
    - they require good voltage supply
    - output range is reduced: 0.4v to 4.8v
    - because the output is digital, you have some jitter in the measure.
  10. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Yes, go with hall effect pots. In one week both my "conventional" pots "died" after almost a year, and in the last weeks they weren't working well at all, with no precision. The last days you can see the rig moving by itself just turning motors on.
    I bought the TT Electronics 6127V1A180L.5FS too as a replacement.
  11. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    I'm using Bourne 6639S-1-502
  12. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    86Coins
    Any problems with Hall Effects pots? In these days i've some problems with conventional pots...
  13. noorbeast
    152,571Coins
    +11,087 / 56 / -2
    I have found Hall sensors to be very reliable and durable. They have excellent fidelity and won't break in a motor runaway.
  14. Nick Moxley
    Halls are MORE Than Durable, Lol I locked one up to a point of needing a LARGE pair of pliers to free it up, Added a drop of oil and its been good ever since. Have no fear, halls are here. :grin
    PS thinking back, I actually locked up the same pot twice, Once i got the Flex coupler's on and a Flexible Pot mount, everything went butter smooth.
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    I've tried and killed a lot of pots, carbon film, cermet, wirewounds. The halls are by far the most reliable and durable. I use the 360's with gear reduction instead of the 180's direct. The only type that was even close to as smooth and accurate was the bourns. The halls also offer a very low resistance to turning which can help reduce oscillation.
  16. fzxj520
    fzxj520 Active Member
    1,341Coins
  17. DonCorleonez
    DonCorleonez Member
    195Coins
    @Barry is Bourns 5k not 10k?
  18. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Yes.
    I asked about pots a long time ago and a few people recommended those ones for me.
  19. RacingMat
    21,059Coins
    10K is mandatory with Arduino
    with other setups, maybe 5K is okay: read the specs ;)
  20. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    I wasn't aware of that. I'm using JRKs
