My 2-3DOF Scale build Basics - get up and running?
Discussion in 'DIY Motion Simulator Projects' started by John458, Feb 9, 2016.
  1. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hey everyone,
    I am itching to build my own motion sim, however I know very little about coding or electronics in general. I can easily follow instructions thou and have come quite a long way since I started. I have been through many a thread and have found little bits here and there that I can understand, and a lot I cant.
    The first project is a 3DOF system. However just to get my head around things I am starting with a 2DOF scale build so I can work out how the electronics and coding work to the best of my abilities. So far with @RufusDufus help on this thread
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    I have managed to build a basic electonics rig with 2 little dc motors .I have got the code installed (SMC3 v0.7) and have used the simtools utility and it seems to be working and showing me the pots are sending a signal etc.
    I then went through the setup guide for the sim tools game engine and manager. Patched LFS and then went through and setup as per the instructions. http://www.xsimulator.net/simtools-quickstart/
    However I cannot get the motors to move at all.... nothing happens... im so close and ill post some pictures (my current wiring diagram) here and a video I created to show you where Im up to.
    Looking for some help to make it finally work! and then move onto making the third motor move as well :)
    Cheers and I'm hoping this thread will help others who want an easy get up and running guide
  2. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    1.interface settings are wrong
    Simtools Setup
    Setup for Simtools is very straight forward:
    [A<Axis1>][B<Axis2>][C<Axis3>]
    Set for 10bit binary output
    from here http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    2.you need to configure a profile for live for speed in game engine under game list(this is my profile yours might be different )
  3. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @insanegr Thanks for your help,
    I have tried changing those settings to the correct ones but still nothing. Have also created a profile and tried using the default ones, no luck. tried plugging in my 9v to the monster moto.. no go...
    I did notice that when I selected the test output section in the game engine the RX light on my arduino board comes on.
    Do you think nothings happening because I only have 2 motors wired up instead of 3? and should I need a 9v battery connected to run the small motors?
    after that I did try and put just [A<Axis1>][B<Axis2>] removing the C Axis to see if that would work but no luck..
    here are some screenshots to show the changes..... hmmm no idea
    Cheers
  4. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    if you want to see some motion you have to connect yous pot's on motors shaft but you have to configure it in SMC3 first and then move in simtools
  5. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @insanger
    Thanks for pointing that out, and i appreciate your patience ...feel like an idiot for missing that... it feels like drinking from a firehouse sometimes.
    update..ok I tried all of that and still no motors moving, I did even plugin another monster moto board I brought just incase it was that.... still no movement.... I'm going to have a good read through again and check all my wiring to make sure its all in the right spots to the diagrams.
    Fingers crossed and ill let you know how I go :)
    Have a great weekend ahead
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    post pics of your wiring and the rest of your project we can assist you better that way. there are some good eyes here. they may even see stuff that wont be a problem until later in your build.
  7. Federico 80
    Federico 80 New Member
    436Coins
    Very interesting Topic! Thank you!
  8. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,303Coins
    Yes you will need the 9v battery (or similar) connected to the H-Bridges battery supply input to drive the motors.
    If the POTs aren't mechanically connected to the motors all you will notice is the motors seem to get faster and slower or change direction.
    Do you have the MODE setup in the arduino code correctly for use with MOTO Monster H-Bridges... MODE1 from memory - check the SMC3 post to confirm.
  9. Pit
    30,497Coins
    There are many things you can do wrongly, in any case go slowly forward and step by step. The SMC3 manual is easy to follow and for an analysis of your hardware please upload more pictures like the wiring etc.
  10. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Eureka! Finally my 2 motors are spinning when I increase the PWMax settings within the utility. Now I excitedly tried it with the game engine and used the correct interface settings provided. tried the output testing under DOF and Axis output but no movement.. interesting... one step at a time... more reading and studying to follow..
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    not sure about the startup and shutdown arguments. those fields are blank in my setup.
  12. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @RufusDufus Thank you for your help thus far. I have successfully got the 2 motors running and working with the utility tool. I am now trying to add the third motor, but am unsure of the wiring. I have found one for 4 motors but it is so different to the 2 motor setup in your thread im not sure where to start. adding the pot is fine, grounding and adding the 5v connection is now stright forward to me. Just wondering where pin 11 PWM goes to the 2nd monster moto as well as pins 7 and 6 for the third motor. Please see diagram attached its the pink lines. Cheers and thanks again for your help. Once working I will post another screen shot of the connections for others to follow in the future Test Board 3 motor_bb.jpg :)
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    This is copied from FAQ
    SMC3 code can access up to 3 motors using one Arduino. If you want to connect 3 MM please wire described as follows:
    Arduino -------- Monster Moto
    2 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    3 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    9 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 2
    4 (Motor 2 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    5 (Motor 2 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    10 (Motor 2 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 3
    6 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    7 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    11 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    The outputs:
    A1 and B1 will have the SAME polarity
    A2 and B2 will have the SAME polarity, too.
    Hope this helps
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    I know it's for 3 monsters but it does illustrate where the wires come off of the ard. The only thing is they are doubled up at the monster.
  15. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Ok thanks Bruce,
    yes I saw that but got confused with the doubling up on the moto.
    so if I have got this right
    6 (Motor 1 H-Bridge ENA) ---------------7 for (INA1)
    7 (Motor 1 H-Bridge ENB)----------------4 for (INA2)
    11 (Motor 1 PWM) --------------------------5 for (PWM1)
    then the motor will run off the a1 and a2 left hand side of the board
  16. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    opps thats not right... a1 and b1... hmmm motor is only moving one way...
  17. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    ok have got it...
    7 (Motor 1 H-Bridge ENB)----------------8 for (INB1)
    success!
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    Sweet glad you got it going.
    also remember you can hook up a pot to a5 and use pot scaling with SMC3. essentially its like a realtime volume control for your motion.
  19. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Cool thanks @bruce stephen i'll give it a go.
    Just a little bit more help if I may :)
    I just had a bit of a realization today .( As long as it has taken me to figure this stuff out so far, and build this and finally get it working), its maybe not gonna work for the scale model. It will for the final build I'm using worm gear motors so thats fine for that.
    But because I'm building a 50% scale model out of 3mm MDF (very cheap) the little DC motors i was going to use dont have enough torque to move the thing... so i got a motor with a gear box that had 2.1kg torque but only 70 rpm... so slow... then I realized I need a motor with high rpm and high torque which is hard to find for that hobby size,(well that I can't seem to find)
    long story short it seems servos that can move 15kg at .18 at 60 degrees would do the job, however I cant seem to find out how to connect them to the moto shield as they are not + and - connections like a motor.. they have 3 wires i think... the GND the POWER and the PWM
    hmmm where to from here.... is there a way to connect them to my current setup?
    this is the one Im looking at?
    Model: HDKJ D3015 (15KG metal gear, wide-angle, high torque, digital, waterproof servos)
    Dimensions: 4 x 4 x 2 cm
    Cable length: 30cm
    Weight: 60g
    Deadband setting: 4 microseconds
    Maximum rotation angle: 300° (The plug, output gear and remote control system are compatible with Futaba, JR, HITEC)
    Working Torque: 14Kg.cm. at 6.0v
    15Kg.cm. at 7.2v
    Speed: 0.18sec / 60° at 6v
    0.16sec / 60° at 7.2v
    No-load current: <500 mA
    Working voltage: 4.8 - 7.2 V by566_4.jpg
  20. eaorobbie
    20,487Coins
    Use my RC Model code and reuse the Arduino and you can save the MM's for the full build, plus reuse the Ard again for the full build but using SMC code.
