value1
Codemasters Dirt 3 Plugin 2.0.0.1
SimTools plugin for Codemasters Dirt 3
  1. matrixpascal
    matrixpascal Member
    305Coins
    Good evening.
    ca ca is working.
    I made a mistake I'm x64.
    so I remove the patch and I put in my papers and AC works.
    thank you is what my help.
    another question.
    there is there a patch intended for wrc 5?
    154,502Coins
    +11,184 / 57 / -2
    Glad to see you got it sorted.
    There is no motion for WRC 5 yet. There is one for Dirt Rally though, which would be the best alternative.
  3. matrixpascal
    matrixpascal Member
    305Coins
    thank you.
    but I has not yet dirt rally, it is too expensive at the moment, but I wrc 5 that is why I asked the question
  4. obobo
    obobo Active Member
    1,323Coins
    I have a problem with Dirt3 complete edition
    I patched the game as stated in game manager (game directory)
    Simtools goes well in blue, but nothing in tuning center and no movements in the game ...
    Has anyone ever encountered this problem?
    j'ai un problème avec Dirt3 complete edition
    j'ai patché le jeu comme indiqué dans game manager (répertoire du jeu)
    simtools passe bien en bleu, mais rien dans tuning center et aucun mouvements dans le jeu ...
    quelqu'un à déjà rencontré ce problème ?
    154,502Coins
    +11,184 / 57 / -2
    Are you on a 32 or 64bit version of Windows and what path did you patch to?
  6. obobo
    obobo Active Member
    1,323Coins
    64bits windows
    patch in steamapps\common\dirt3
    154,502Coins
    +11,184 / 57 / -2
    For 64 the patch path is the Dirt 3 folder in My Documents/Games, so unpatch and re patch to that and see how it goes.
  8. obobo
    obobo Active Member
    1,323Coins
    ok i'll test this in a few time
    in the game engine, the message should be amended to indicate the difference between 32 and 64 bit
    dans le game engine, le message devrait être modifié pour indiquer la différence entre 32 et 64 bits
  9. obobo
    obobo Active Member
    1,323Coins
    I just do it, it works,
    By cons, last night, I had a little everything try and this morning, removing the patch, was already in the directory that is in my documents ....
    I do not understand why yesterday it did not work, but after removing the patch then re applied it works. it is essential
    je viens de le faire, ça fonctionne,
    par contre, hier soir, j'avais un peu tout essayer et ce matin, en enlevant le patch, jétait déjà dans le répertoire qui est dans mes documents....
    je ne comprends pas pourquoi hier ça ne fonctionnait pas, mais après avoir enlevé le patch puis ré appliqué ça fonctionne. c'est l'essentiel
  10. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Hi, i just updated to Simtools v2 and all the games i have tried worked perfectly, but with Dirt 3 when i start the game the actuators start up and down like crazy.. Do you know what can im missing? Thanks!
    154,502Coins
    +11,184 / 57 / -2
    My guess is the default Tuning Center values are pretty low, if I recall Dirt 3 has telemetry data as soon as a level loads.
    What you could try is turning the Main Level down in the Profile section of Game Manager, then do a base setting run for the Tuning Center values: https://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
  12. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Thanks for the advice, but with main level at 0, the actuators still doing it thing like crazy.. Strange! :(
  13. noorbeast
    154,502Coins
    +11,184 / 57 / -2
    It would help if you create your own troubleshooting thread and post all your settings.
  14. MorciXL
    MorciXL New Member
    Spain
    153Coins
    2DOF, SCN6
    Here is my config.. im not doing anything different as on 1.3 version and everything was working fine.
    Any help would be appreciated.
    Thanks!
    http://imgur.com/a/Guvfg
    Pd.- Just realized that Project Cars is doing the same strange thing using Simtools 2.0
    Dirt Rally and Assetto working perfectly, but D3 and Pcars, unplayable..
    Edit: FIXED.. ! I was trying diferent configs on Tuning Center, and finally works well now.
    Thanks for your help.
  15. hyper1966
    hyper1966 Domenic
    Edmonton QLD Australia
    833Coins
    2DOF, JRK
    Can some help me please
    doesn't seem to work with Game Dash ,its not present in Sims tool profile editor .Work fine before with sims tool 1.3 version .Look at picture ,I have added pic of Profiler Thanks domenic
  16. yobuddy
    51,667Coins
  17. hyper1966
    hyper1966 Domenic
    833Coins
    2DOF, JRK
  18. dlxodud1719
    dlxodud1719 New Member
    korea
    141Coins
    i want play dirt 3
    how much coin this plugin?
    154,502Coins
    +11,184 / 57 / -2
  20. DFLMJ
    DFLMJ New Member
    中国
    135Coins
    我也想下载这个插件。谢谢您!
