Simulated Wind using 220V fan (and ArduinoUno?)
Discussion in 'DIY peripherals' started by Pit, Mar 27, 2016.
  1. Pit
    30,490Coins
    I would like to use a 220V fan (100W AEG motor, detailed specs are not yet available) for simulating wind and as far as I know there is no such DIY project out here? If there is no solution I can replace the motor (to 24V) but I would like to stay with 220V if possible (because of too much work...).
    Any helpful links and other useful information are much appreciated.
    152,201Coins
    +11,065 / 56 / -2
  3. Historiker
    9,208Coins
  4. BlazinH
    16,666Coins
  5. RacingMat
    21,051Coins
    • Informative Informative x 3
  6. Pit
    30,490Coins
    Hey guys, such a great help in such a short time, thank you all and there is more than only one solution, finally I have all what I need. IMO the solution of @RacingMat is the easiest one because it is also possible to control the dimmer module M012 using control voltages between 1 - 5 V which makes it compatible to the Ard. PERFECT!
  7. Pit
    30,490Coins
  8. BlazinH
    16,666Coins
    An arduino with a low-pass filter on the PMW output should control it.
  9. Pit
    30,490Coins
    Like this one? Low-pass RC filter using a 10kΩ resistor and 2.2uF capacitor.
  10. Historiker
    9,208Coins
    Hey Pit, when you get it all sorted would you create a FAQ for building an Arduino AC Fan setup? We have lots of info on DC fans but this would be a great addition to the FAQ section.
  11. BlazinH
    16,666Coins
    Those component values should work fine for fan control. If you were going to use a low-pass filter to drive a rig though you would want to use a much smaller capacitor.
  12. Pit
    30,490Coins
    Agree mate, that's how it will be :)
  13. RacingMat
    21,051Coins
    hopefully you don't burn Hbridge anymore... because you should not blow on the fire! ;)
  14. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
  15. Pit
    30,490Coins
    I have taken precautions
    • Funny Funny x 3
  16. RacingMat
    21,051Coins
    perfect!
    I'm eager to see your video : wind.gif
    • Funny Funny x 2
  17. maweish
    maweish New Member
    - 97Coins
    No bad Idea. For this you could use Solid State-Relays (Type for Mains) l.
    An maybe safer alternative could be a simple light dimmer-switch mechanically hooked up to a servo that tunes it.
    But always when you do something with voltage up 100 Volts you should know what youre doing! In case use the help of an electritian.
    If it is tool dangerous to you, use 12 Volt fans.
    (unfortunately i cannot post links, it thinks this is spam -_- )
  18. Pit
    30,490Coins
    You are wrong mate, 12v can lead to death as well. It's mostly the amount of current flowing into a vital organ that causes death and not only the high voltage...
  19. BlazinH
    16,666Coins
    As little as 1/10th of an amp of electricity across the human heart can cause fibrillation and possible stoppage. However, the average human body has quite a bit of resistance to electricity flowing thru it. Therefore, it would take a lot more then 1/10th amp going in to get that across the heart.
    The main danger factor though is the type of electricity. When shocked with DC current you can and will quickly move away from the shock (ever been zapped by a spark plug?). AC current on the other hand causes you to adhere to the shock due to the nature of alternating current. Instead of your muscles pushing you away as with DC, they fibrillate so you can’t move with AC.
  20. Boomslangnz
    4,170Coins
    I have recently brought some 12v fans and servos & esc's. Been testing out wind simulation on a ard, why not just keep it simple by doing something similar? These fans blow hard, curtains other side of room were flapping about when I increased the speed
