PGSaw Motors max. Temperature ?
Discussion in 'Motor actuators and drivers' started by Lorien31, Mar 27, 2016.
  1. Lorien31
    Lorien31 Member Gold Contributor
    IT System Specialist
    140Coins
    Hello all
    i have for quite some time now a seat mover with traction loss with arduino smc software.
    Works great! Only "problem" i have now since i got my Heusinkveld ultimate pedals, that my motors are getting warm.
    Reason is that the brake pedal needs a lot of brake force now, thats why the motors warm up.
    They have a outside temperature of around 40C° after maybe an hour heavy racing in iracing.
    Also asked PGSaw if he knows the max temperature but so far he couldn't tell me yet.
    So i know quite a lot here use these motors, or have similar which maybe have temperature specification.
    Is it save to drive em like that, or do i have to change something, maybe optimize the angles or levers ?
    I know from my 3d printer stepper motors that they run at 60°C all the time, but this is no stepper motor.
    152,111Coins
    +11,065 / 56 / -2
    For now do add some fans while you get it sorted. it is simple and cheap to do.
    Do post some pictures of your motion sim so members can advise regarding possible design changes.
    Some members drill holes in the motor case to get greater air circulation and cooling.
  3. Lorien31
    140Coins
    Yeah was thinking about the fans, but not sure it helps any because of the flat round surface of the motors ?
    Do you know which member it was that drilled holes in those pgsaw motors, quite dangerous for the motors ?
    I attached a picture of my sim.
    152,111Coins
    +11,065 / 56 / -2
  5. Nick Moxley
    Correct, you dont have Any real leverage going on there. those motor's are bound to run hot hot with those angles.
  6. Historiker
    9,208Coins
    Your angles are trying to lift rather than tilt. Which is easier; lift a heavy object or tilt it over? :) Those motors are working really really hard.
  7. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
  8. Lorien31
    140Coins
    Hmm how much angle do i need ? Currently the angle between the seat frame and the rod is 30°.
  9. pipis2015
    Athens, GREECE
    10,248Coins
    This is the way to achieve tha maximum force...
    Try to have 90 degree angles at both ends at rest position.
    A 90 degree angle on the motor side is easy.
    On the shoulder side you should target for as close to 90 degrees as your design permits.
  10. pipis2015
    Athens, GREECE
    10,248Coins
    This next pic explains clearly why you need to be as close to a 90 degree angle to maximise performance.
    If the angle between F and R is 90 degrees (θ=0 degrees) then cosθ=1 so the force result is maximised.
  11. Lorien31
    140Coins
    Ah thanks. So if i mount the motors further back and maybe a bit higher from the ground, and keep a 90° angle at motor side, should help the situation i'm in ?
  12. pipis2015
    Athens, GREECE
    10,248Coins
    if you follow the above then you reduce the stress of your motors for a given task.
  13. BlazinH
    16,665Coins
    Maybe I’m the only one with this opinion but your motors are barely getting warm after one hour. I don’t think you have a problem. My motors get that hot in 5 minutes and can run 55c with rally and F1 type driving. Of course, not all motors are the same. Imo if you don’t smell any burning or hot type smells or your motors aren’t loosing power when they seem hot then they probably aren’t getting to hot.
    Onetime I had some motors on a platform that somehow got left on for three hours. By the time I found out they could barely hold up any weight anymore nor could I touch them they were so hot. I thought they would be ruined but after they cooled down again they worked fine.
  14. Edaurdo
    Edaurdo Member
    Buenos Aires, Argentina
    190Coins
    Hello Lorien31! I am starting the construction of my first 2dof. I bought two PGSaw motors like the ones you used.
    In my case they are engines have the following characteristics:
    - Ratio 1:50
    - 180w
    - 12V
    - 50NM
    In order to design a suitable framework, could you tell me if your engines are like mine?
  15. Lorien31
    140Coins
    My motors do have a gear ratio of 25:1, with different lever length you should be fine i guess.
  16. Edaurdo
    Edaurdo Member
    190Coins
    Thank you very much for your answer! I will surely inspire you in your frame
