value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. mohammad
    mohammad Member
    iran
    159Coins
    Hi friends
    I install the dcs patch, but in the game can not data to the tuninig center why?
  2. Historiker
    9,205Coins
  3. mohammad
    mohammad Member
    iran
    159Coins
    The problem was solved
    The problem was-region
    change to us is ok;)
  4. GusBiz
    GusBiz New Member
    Sales IT
    Melbourne, Australia
    486Coins
    DC motor, AC motor, Arduino, Motion platform, 6DOF
    @value1 I have a special request for the DCS plugin. Would you be available for a skype session. I am willing to pay you for it if you like. I am designing a flight 2 DOF gimbal similar to a a gyro with a 6 DOF chair at its centre. (I have attached an image for it ). This means that there are two additional motors that rotate the Gimbal rings for pitch and roll. I take it this will need some special attention so that the pitch and roll is not sent to the 6 DOF chair. I can work this out myself but it will be quicker with your help. Either way I completely appreciate the work that you have done on this plugin so far. Thank you.
    154,358Coins
    +11,179 / 57 / -2
    Your question is really one about design and configuration and is not specific to the DCS plugin, hence you should put it in your own build thread.
    SimTools 2.0 is in closed beta testing and can handle 12 simultaneous axis calculations, so configuring 8 will not be a problem: http://www.xsimulator.net/community/threads/simtools-2-0-question-and-answer.8175/
  6. GusBiz
    GusBiz New Member
    Sales IT
    486Coins
    I will start my own Build thread but I felt that this question relates more to this plugin than anything else only because it is about isolating the pitch and roll out of the 6 DOF chair, yet still getting the heave, sway, yaw, and surge out of the central chair. Its not really about getting additional axis as it only exercises 6DOF in total. Its more in how the inputs from the game are interpreted by the SimTools software.
    154,358Coins
    +11,179 / 57 / -2
    Actually you define what force you allocate to an axis and tune it to suit, so with SimTools 2 you can allocate the 6DOF to the chair plus additional roll and and pitch axis, as there will be 12 axis supported.
    With such a complex and potentially costly project I would recommend you create your own build thread and make either a SketchUp or RC powered model to test your ideas, before you invest a lot of time or resources:
    http://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
    http://www.xsimulator.net/community/faq/build-a-working-model-to-test-your-design-ideas.216/
  8. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
    @value1 I have identified an extra value which would greatly benefit this plugin. local slipball = LoGetSlipBallPosition()
    I sent you a PM with the details
  9. RiftFlyer
    1,711Coins
    DC motor
    I have researched this a great deal over the past few days. I've now found that the slipball and turn indicator values are named differently depending on the aircraft used.
    The export.lua script used by the plugin needs to be a little more complex. It needs to first identify the aircraft being used and based on that information call the correct instrument names to obtain the right values.
    I have started coding an export.lua file which will output the necessary values. Is it at all possible to get the plugin source code so I may attempt to add to the plugin for the community?
    I don't want to have to start from scratch and unlike the LFS and other plugins the source code for dcs is not available only the dll. I hate to be bothering others to do this work as new aircraft releases mean new amendments will be required. I'm also anxious to get stuck in as my project can't work without these modifications.
  10. RiftFlyer
    1,711Coins
    DC motor
    Here is a helicopter tuning flight I completed. From the numbers it can be seen that no usable force value is being output for stationary pirouettes. The turn indicator and slip ball instrument can be seen at the bottom of the instrument panel. The turn needle deflection corresponds with rate of turn even when in a stationary hover. It is this value along with that of the slip ball on the same instrument which I would like to add as extra forces. Like I've said above the naming of these in the export.lua differs between aircraft although it is present on all of them.
  11. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    hi all
    Finally got everything going in sim tools using LFS to check and everything fine
    But DCS no motion, sim tools see DCS "game running" but zero motion
    Any idea's. ?????????
    Ps I'm running the steam version of dcs and downloaded the dcs plug in today
  12. RiftFlyer
    1,711Coins
    DC motor
    -Have you checked the game patched correctly? ie that the export.lua file is in your saved games/dcs/scripts folder (I think the path is the same for the steam version but double check the file has been correctly installed.
  13. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    I'll check that shortly, it said game patched etc + sim tools went blue game started etc
    which leads me to believe that side of things are ok
    I only got going with sim tools earlier but got everything running in LFS no probes with motion etc
    I really don know what to do
  14. RiftFlyer
    1,711Coins
    DC motor
    in addition to checking the export.lua open dcs and tuning centre together and see if you have numbers shown in the top row while in flight like in my video above.
    ensure you have axis assignments and the interface settings tabs completed for dcs in game engine. You would have done this already for LFS if you got motion so just repeat for DCS. Select dcs from the drop down menu in game engine and complete the required fields.
  15. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    yes its there, 3kb file in correct place
    still no joy )-:
  16. RiftFlyer
    1,711Coins
    DC motor
    I had a lot of issues initially. It was down to me not setting up game engine interface and axis settings tabs correctly.
    Keep trying and if you've no joy I'll explain how to test if DCS is outputting data tomorrow. It requires adding some more code to the export.lua and checking a log file it creates. I'm not at my PC at the moment to get it for you.
    • Friendly Friendly x 2
    154,358Coins
    +11,179 / 57 / -2
    With DCS the patch path is the save folder, not the install folder. Is that what you patched to, like this: C:\User\User Name\ Saved Games\DCS
    For some games running Gaming Engine and Game Manager in admin mode helps.
    For a flight motion profile you need greater axis % allocations than a race profile and you do need to use filters to manage the 180 degree transition points for roll and pitch.
  18. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    bug thanks that sorted it ! top man
    just got to sort the motion now everything mixed up ,
    phew thank goodness its going
  19. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Hi all,
    I have everything feeling convincing and pretty good for first settings
    Only using roll and pitch .....matching that of the aircraft ( unlike racing Sims where I set for g forces)
    Landings feel Brill
    Just a question when loop the loop or a 360 degree roll half way the software snaps the position to the far opposite to match data , instead of rolling in opposite direction is there any option to change this ?????
    (sim commander in race Sims when car flips etc handles this very well)
    EDIT : the "washout " setting is the only way to do this ?
    I'll read the instructions and test for the other effects ( yaw etc , should be simple now )
    154,358Coins
    +11,179 / 57 / -2
    Personally I find smoothing is more effective than the washout filter, give it a try.
    As an aside just so you know the FSX/Prepar3D plugin has the option to use extra1 and extra2 instead of traditional pitch and roll like in DCS, and they are implemented similar to Elite Dangerous, which for me is far more realistic in VR as it holds the axis tilt until released: http://www.xsimulator.net/community/faq/prepar3d-guide-to-realistic-motion-settings.144/
