value1
City Car Driving Plugin 2.0.8.3
SimTools game plugin for City Car Driving
  1. noorbeast
    153,728Coins
  2. Michael King
    Michael King New Member
    - 46Coins
  3. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    new 1.5.1 version maybe the old plugin operates again?
  4. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    having no more updates of the plugin developers wonder if the data are collected from memory in order to try to create a plugin via the simtools tutorial
    153,728Coins
    It would almost certainly be the memory hook method @spyderwash.
  6. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    ok thanks imagine that only way to work, it would be nice to have more information by the developer to not having to redo all the work and then know that it was enough to change a small thing to put the plug-in operation
    153,728Coins
    Unfortunately the significant changes to the game mean that it would likely not be some small thing that is needed to make the plugin functional. It is more probable that hooks are all different now.
  8. skae87
    skae87 New Member
    - 40Coins
    people who tested citycar driving... is a free demo available?
  9. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    There would be no way to run again this pluggin with the current version? I tried it with the current and not moving, loading the game moves a little, like other games when everything is fine, but then nothing moves.
    153,728Coins
    As I mentioned the latest version is significantly different, so the plugin needs to be remade before it will function again. As plugins are done by committed volunteers that will happen when they can find the time in their busy lives.
  11. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    I understand noorbeast, thanks. I am totally denied for this, but I would like to run this simulator with movement, I'm teaching my nephew to drive on this simulator which is fine for his first class and if I put the motion would be perfect. I do not know why the previous plugin only exported data Pitch, Roll and Yaw, could not be exported data sway, surge and heave? If any of those people who dominate this topic could do well again this pluggin would be fantastic. I purchase and gave her a product key to do it, and enjoyed it everyone in the community too. Let's see if anyone is encouraged
    Sorry for my bad english friends
  12. luky_90
    luky_90 Member
    276Coins
    someone updated plugins or is still quite firm ?
  13. noorbeast
    153,728Coins
    Not yet.
  14. AlexinChina
    AlexinChina Member
    China
    371Coins
    I test 1.5.2 use this plugin, it not work.
    I hope you can update this plugin. thank U!@noorbeast@value1
    1.5.2 can use VR glass, it's really cool!
    153,728Coins
    SimTools 2.0 is not far off being released and plugins will need to be updated, so I can't see City Car Driving being updated until SimTools 2.0 is out and plugins are updated in whatever priority order is set.
  16. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    the plugin is only functioning with simtools version 2 while the 1.3 there are no updates?
    Now city car driving 1.5.3 is this working? It was added some new data as heave
    thank you
  17. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    sorry just now I translated it compatible with version 1.53 of steam hope even with no steam version
  18. value1
    14,236Coins
    The current plugin is working with SimTools V2 and Steam 1.5.3.
    It provides
    Pitch, Roll, Yaw and Surge. Other values (including Heave) I have not found.
  19. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I ran a few tests the game is detected, but I have no use moving version 1.5.3 no steam outlet directly downloaded from the manufacturer in center 02/01/17 output tuning does not have values, you can run a test
    thank you
  20. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I downloaded steam version and the game works thank @value1
