Can't press the start button XSim2
Discussion in 'Force-Profiler Simulator Control' started by angel, Oct 20, 2008.
  1. angel
    angel New Member
    0Coins
    Sorry for my English.
    When I want to you press the Start button (in the force profiler 2.o)(XSim2) I cann´t do it. this is disabled. Why?
    I have everything configured properly. The force sender send me all of data,
    The game (rfactor) also sends me the data
    Help. Thanks.
    Cuando pulso el boton Strart (en el force profiler 2.0) no me deja, este está deshabilitado, porque?
    He configurado todo correctamente. El force sender me envia todos los datos, el juego (rfactor) tambien me envia todos los datos.
    Ayuda. Gracias.
  2. el_txus
    el_txus Member
    Las Palmas de Gran Canaria - España
    421Coins
    Hola Angel
    Para poder usar el profiler 2 hay que crear un gauge y enviarselo a SirNoname por correo junto con el numero de ID de tu ordenador, como colaboracion al proyecto, si no realizas este pequeño proceso no recibirás la clave el desbloqueo y no se te activará el boton start en el profiler 2.
    Puedes leer el texto completo aqui http://www.x-sim.de es el de color Rojo
    Saludos
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    We have enough gauges recently. An infopanel would be great now.
    The final X-Sim2 release will be free, but as long as X-Sim2 is in BETA status, only active supporters get a key to unlock the profiler.
    So, you can decide if you want try to make an infopanel with the gauge-editor, or you wait for the final X-Sim2 release, and use X-Sim1 in the meantime.
    forming-group-of-tests-to-beta-english-only-t948.html
    Regards
    Christian
  4. angel
    angel New Member
    0Coins
    Ahhh !!
    OK :)
    Thanks.
