assetto corsa
Discussion in 'SimTools Plugins' started by DE CASTRO, Apr 3, 2016.
  1. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    bonjour a tous j'ai un petit soucis sur assetto corsa version 1.5.3
    depuis cette mise a jour le plugin ne fonctionne plus.
    un peu d'aide serais la bien venu.
    merci à tous.
    Hello everyone I have a little problem on Assetto Corsa Version 1.5.3
    since that update the plugin no longer works.
    a little help would be the welcome.
    thank you all.
  2. Nick Moxley
    Nothing changed with the update as far as the motion is concerned. Have you tried to tried to re install the plugin and make sure the game path is correct ?
  3. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    oui j'ai reinstaller le plugin et le patch me dit que c'est ok
    yes I reinstall the plug and patch told me it is ok
  4. Nick Moxley
    And have you checked your Tuning center hasn't changed ?
  5. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    bonsoir ça y est tout remarche merci.
    hello there it is all working again thank you .
  6. Nick Moxley
    Tuning center values ?
  7. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    Bonjour je ne sais pas si c'était le tunning centre value mais ça fonctionne correctement merci.
    Hello I do not know if it was the center tunning value but it works properly thank you .
  8. Nick Moxley
    Did you change the tuning center #'s Or What did you do to solve it ?
  9. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    bonjour,
    j'ai ouvert tuning center rien de plus mais j'ai réinstaller le plugin et ça à remarcher je pense que c'etais ça.
    merci.
    I opened center tuning nothing more but I have to reinstall the plugin and that to walk again I think it Was .
    thank you.
  10. eaorobbie
    20,502Coins
    Cool its fixed then.
    Sometimes with game updates the patching of the game is broken, Dirt Rally does this too, Its just a matter of re patching for motion again.
