Is possible use steep motor with sim tools
Discussion in 'DIY Motion Simulator Projects' started by jefesant, Apr 3, 2016.
  1. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    I want know if is possible to conect the steep motor on simtools
    If yes maybe we can use the linea actuators by steep motor and good acurace ..
    thanks in advance....
    153,938Coins
    +11,158 / 57 / -2
    I think you mean stepper motor?
  3. eaorobbie
    20,503Coins
    Can be done but you need to adapt a custom library or use straight pin control as most stepper library cause a blocking command to serial while the stepper is moving, causing major lag in movements,
    The trick is to make one step per motor per loop of the program......
