Sketchup & SketchyPhysics Simulation FAQ
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by speedy, Dec 30, 2015.
  1. noorbeast
    153,703Coins
  2. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Problem solved :)
    -I have only preserved the original Socket.so and Socket.rb of Sketchup 2015
    -In the Interface Settings of SimTools: <Axis1>; <Axis2>; <Axis3>; with the capital letter A in thank you @noorbeast .Absolutely necessary!
    Problème de connection résolu :)
    -J'ai uniquement laissé le Socket.so et Socket.rb d'origine de Sketchup 2015
    -Dans Interface Settings de SimTools: <Axis1>;<Axis2>;<Axis3>; avec le A en lettre capitale ;) merci @noorbeast Absolument nécessaire!
  3. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    3DOF, Arduino, SimforceGT, Motion platform
  4. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    how can i give you file for sketchup pro? cannot upload here..hurmm..:(
    153,703Coins
    Did you try zipping the file @Malik10?
  6. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    help me please..hurmm..:(
  7. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    if used hinge cannot connect to simtool?cannot giving motion?
    153,703Coins
    Can you please upload the Sketchup file.
  9. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    because of the nature of hinges or sliders that doesn't give a moving force to the model by itself ... so SimTools won't be able to move it ... just use the servo or pistons and you'll find the text box that can be renamed to "$axisX" .
  10. speedy
    Alexandria , Egypt
    7,948Coins
    a teasing view of the Drifting simulator work done so far :p ... sorry for not much space to get a better landscape picture ...
    20160404_234933.jpg Physics ASP base full structure1.jpg Physics ASP base full structure2.jpg
  11. Mic_n
    Mic_n New Member
    Sydney
    431Coins
    Possibly worth noting.. I was seeing that same sort of latency as mentioned (using Sketchup 2016), and after much messing around, I seem to have sorted it out (for myself, at any rate) by modifying the sampling rate in the ruby script itself.
    That 'timer' line in the .rb file - try dropping that value down to a lower number (I added an extra zero) to increase the sampling rate used by sketchup. I'm not sure why it's behaving the way it does there, it doesn't seem to make much sense on the surface, and I don't know enough about ruby and its UDP socket handling to make a guess as to why, but changing that value made it much more responsive for myself.
  12. Mic_n
    Mic_n New Member
    Sydney
    431Coins
    Also (and I'm not sure if this is really the right place or not).. looking for a little help with creating universal joints in sketchyphysics.. Is the 'joint' entity itself supposed to be grouped with one shaft and then joined to the other? Is the 'middle' bit (I don't actually know the term for it) where it should be grouped, and then joined at both ends? The only tutorials/guides I can find out there are pretty generic and don't really go into it.. I note that the Wackelstuhl uses a ball joint there, which isn't really correct since it doesn't maintain the torque through the chair (though I'm guessing it's "nailed down" with a parameter in there preventing the rotation?)
  13. speedy
    Alexandria , Egypt
    7,948Coins
    Been there and the same question from me too ... like this previous post .
    ended up using hinges like this ...
    • Useful Useful x 2
  14. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    sorry..this is my real file used servo
    • new.zip
      542.9 KB
      528
  15. speedy
    Alexandria , Egypt
    7,948Coins
    your file is sketchup 2016 and I'm using 14 can you save it as version 2014 ?
  16. noorbeast
    153,703Coins
    Sorry but I do not have a 32bit 2016 version of Sketchup installed, which is what I am guessing you created this file in, as I can't open it.
  17. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    ok i will try it..
  18. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    can u open it?
    • 2014.zip
      541.1 KB
      578
  19. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    what version u have?
    153,703Coins
    I have the 32 bit version of 2015 installed and setup for SimTools.
