2DOF compact seat mover
Discussion in 'DIY Motion Simulator Projects' started by pipis2015, Mar 14, 2015.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    ty @pipis2015 this looks like a fun project. so for about 50us i can build an hydraulic brake input. Never enough time to build everything i want to.
  2. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    I completed the mod without removing the internal dual springs of the t500 brake pedal.
    First impressions.
    I don't know how much trapped air is inside the cylinder(this can be changed to one's taste)... But the for the first 60-70% of the brake force the pedal has a small amount of travel and the next 30-40% (from 60-70% up to 100%) the braking force is applied by pressure on the pedal without pedal travel at all.
  3. pipis2015
    Athens, GREECE
    10,248Coins
    --------------------Problem was solved---------------
    Unfortunately my joy did not last long.
    After leaving the rig for a while to get some rest ...when I got back the press sensor seemed to give no output signal.
    I can't believe I damaged the sensor.
    Did I get that far over 500psi to destroy it?
    Well ... I ll have to wait for a new one to come from the "east"... preferably a 1000psi sensor and see what went wrong...
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
  5. pipis2015
    Athens, GREECE
    10,248Coins
    Yeah, I had read some info ...but I didn't expect I could manage to go that high with gaming pedals.
    I even thought 500psi sensor was an overkill.
    Guess that's the way to learn by trial and error.
    I thought of having a gauge on the cylinder.
    You re right.
    Thing is I also wanted to keep things simple and low cost.
    (Some times cheap is more expensive...).
  6. RacingMat
    21,082Coins
    Keep going! :cheers
  7. pipis2015
    Athens, GREECE
    10,248Coins
    So following @bruce stephen 's advice, I bought a gauge to measure and be sure of what sensor to use next.
    I will update once I get the gauge.
    For the time being its back to stock.
  8. pipis2015
    Athens, GREECE
    10,248Coins
    Another update on the sensor.
    I have been searching all weekend about how these press sensors work, their tolerance etc.
    Well, I found out that they have a mechanical tolerance that is in excess of 200% of their rating. In fact some sheets state 2x-4x the rated max value (1000 to 2000psi for a 500 psi sensor).
    Given the fact that the way my master cylinder is mounted, there is almost no leverage ( my foot presses straight on the pump...there is no leverage to multiply the force) I couldn't convince myself that I damaged the sensor.
    So I re-soldered the sensor cables and mounted the cylinder once more.
    And the damned thing worked flawlessly...
    I will be posting some pics tomorrow.
    • Winner Winner x 3
  9. pipis2015
    Athens, GREECE
    10,248Coins
    Next thing i will try to measure the force needed for full braking.
    For the moment i estimate it somewhere between 25 to 40 kilos (roughly 250 to 400 newton) but i could be wrong.
    Once i have a confirmed reading from a reliable instrument i ll post the results.
    As a first impression the pedal feels harder to fully push than an everyday cars pedal (with servo assistance when engine is running) but also a lot softer than the feeling of the brake pedal when the engine is turned off (no servo assistance).
    • Winner Winner x 3
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    Nice. How is it interfaced? Did you wire it directly to the existing controller? Or do you have something different. I use g25 pedals with bodnar cable, do you think it will be compatible?
  11. pipis2015
    Athens, GREECE
    10,248Coins
    I unsoldered the brake potentiometer (3 cables) and soldered directly the sensor terminals (3 cables: power/gnd/signal) on the pedal board (just a simple conection board with only traces on it...no electronics at all).
    30' job (25 mins for disassembly and assembly and 5 mins for the soldering part).
  12. pipis2015
    Athens, GREECE
    10,248Coins
    Some extra info:
    The pedals are "fed" with 3.3volts (as are the buttons on the steering wheel).
    But the sensor works fine.
  13. pipis2015
    Athens, GREECE
    10,248Coins
    Last update on the hydraulic brake pedal mod.
    Today i removed both the factory springs from under the brake pedal to "lighten" it.
    So its just the master cylinder now (the cylinder has an internal spring that brings the pump/pedal back to "zero" position when no foot pressure is applied).
    I am very happy with the result.
    The force needed to fully press the pedal is also more in proportion to the (motor) force of the steering wheel.
    Without the springs the brake pedal doesnt become fatiguing even after many laps.
    It still is a lot firmer compared to the stock pedal even with the use of the third spring the so called realistic mod.
    The pedal travel is also enough to be able to modulate the braking force (close to 70% of full stock travel).
    Of course the stock springs can be used to tune the feel to each ones taste.
    Would i recomend the mod?
    Absolutely yes.
    How would i rate it?
    A 10/10 would be a conservative rating especially considering the cost.
    DID I MENTION THAT THIS MOD IS ALSO CONSOLE FRIENDLY ???
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    Too cool. You should post this Brake mod in its own thread in diy peripherals. I ordered the parts today. This is very creative.
  15. pipis2015
    Athens, GREECE
    10,248Coins
    Thanks for the kind words Bruce.
    I plan on making a dedicated thread with all the info gathered when I have some spare time.
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    just waiting on the sensor from china...ty @pipis2015
  17. asdfgg
    asdfgg New Member
    Mechanical Designer
    Pisa - Italy
    876Coins
    nice work dude! :D i'm very interested to the project! I follow it!
  18. Knauba
    Knauba New Member
    143Coins
    2DOF, Arduino, JRK
    Hi @pipis2015, first off: very nice work. Your simulator really catched me. I'm currently building a very similar thing, at least I'm trying to :)
    I've got a question according your instructions on the PSU. You write: "A “Y” cable to short pins 6-9-10". In another instruction, I read 6-8-10 and as I'm not really into electronics and need to believe everything I read, I'm a bit confused now. As far as I know pin 8 is ground so this made more sense to me in the first place and I followed the latter (http://www.ultimaterc.com/forums/showthread.php?t=174225). But unfortunately, when I power up the PSU neither the fan stops spinning, nor there is any power coming out. (4 and 8 are also shorted)
    Before I start the deconstruction, are you really using pins 6-9-10?
  19. Blame73
    Blame73 Well-Known Member
    8,314Coins
    Is it a DPS 600PB?
    if yes: pin 4-8 and 6-10
    take a look here:
    https://www.xsimulator.net/community/threads/how-to-modify-a-server-power-supply-for-12v.5774/
  20. Knauba
    Knauba New Member
    143Coins
    2DOF, Arduino, JRK
    Thanks @Blame73, yes indeed it is a DPS 600PB. That makes it two for 6-8-10 :).
    So most probably my PSU is just broken :(
