value1
NASCAR Series Plugin 2.0.0.0
SimTools game plugin for NASCAR'14 and Nascar NASCAR Racing 2003
  1. value1
    14,995Coins
    NASCAR'14 Plugin - SimTools game plugin for NASCAR'14
  2. value1
    14,995Coins
  3. value1
    14,995Coins
    value1 updated NASCAR Series Plugin with a new update entry:
    Update to include NASCAR Racing 2003 Season
    Read the rest of this update entry...
  4. eaorobbie
    20,473Coins
    Cheers bonus , Thanks , another Fav , covered.
  5. BlazinH
    16,661Coins
    Simtools provides the best motion I have ever had with Nascar Racing 2003 Season. Thanks for adding it to the Nascar Series Plugin list value1! :cool:
  6. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    89Coins
  7. value1
    14,995Coins
    Yep, supports Nascar 2003 and Nascar 2014
  8. bob williams
    IT
    Ermelo, Netherlands
    89Coins
  9. james wheeler
    james wheeler Active Member
    - 22Coins
    I am having trouble with the patching. What folder should I choose?
  10. value1
    14,995Coins
    Hmmm, you should be able to use any folder if I remember right.
  11. james wheeler
    - 22Coins
    i have tried the steam nascar folder and the bin folder inside the nascar folder. What is happening it appears is that the patch keeps switching folders on me and moving to dirt3 or wrc4. then crashing game manager. Is the a way to uninstall a plugin?
    I have uninstalled the nascar14 plug in and installed the nascar series plug in. Patched the game to nascar/bin where the .exe file is held and when I start the tuning center I can see the preset values, however when I capture min/max values nothing happens. The numbers stay at 0 as I play the game. I cross checked if there was a tuning center issuse with Pcars but I can see it values fluctuate. Did anyone else experience this issue.
  12. james wheeler
    - 22Coins
    is here going to be a plug in for nascar'15?
  13. james wheeler
    - 22Coins
    I have tryed every folder under the steam directory to know avail. The values in the tuning center will simply not fluctuate. Also i bought nascar'15 and tried that game as well but it won't load even the default values. Is there something in the games set up that needs to be changed like in project cars or did a steam update mess up the plug in?
  14. BlazinH
    16,661Coins
    I don't use the steam versions so I can't help with that. But if Nascar'15 is similar to the different Game Stock Car versions, you might just need to rename it to a name that the plugin recognizes, like Nascar'14 or whatever its .exe name is since Nascar'15 is not officially supported in the plugin yet.
  15. james wheeler
    - 22Coins
    I will try that but i think it is the plug in itself. I tried it on two different computers and neither worked
  16. james wheeler
    - 22Coins
    I can't change the name of the .exe file because steam will no longer reconize it if i do. Can I change the pluging .DLL file somewhere?
  17. buckeyedutch
    buckeyedutch New Member
    knoxville
    195Coins
    hey gentlemen,thx so much for your work. I would like to know if im doing anything wrong, in the process installing the nascar plugin. I am dropping the zip into the updater and patch . nr2003 does not respond to my dofreality 3dof setup with this plugin running. is there anything else i might need to do? there are so many tweaks and adjustment possible with simtools ! thx for your respond in advance
  18. jeffopp
    jeffopp New Member
    - 33Coins
    I'm in the same boat as James W, above:
    "Patched the game to nascar/bin where the .exe file is held and when I start the tuning center I can see the preset values, however when I capture min/max values nothing happens. The numbers stay at 0 as I play the game."
    The rfactor2 plug-in works fine for me, but not the NR2003 plug-in.
    What could cause that?
    Thanks in advance for any insight on this.
  19. Kass55
    Kass55 Member
    PC support
    315Coins
    Thank you to Value1 for creating plugin.
    Motion makes a big improvement to Nascar as I can feel when I "touch" the wall. Ouch.
    I managed to get nr2003 (a Win XP game) running on Win 7 64 bit PC,
    by disabling DEP (not recommended - check you know risk before doing this).
  20. Garry Samson
    Garry Samson New Member Gold Contributor
    - 61Coins
    Hi, This works perfectly great on NR 2003. Thank you! Just curious on how I will use this to patch Nascar 14 as it is showing as NR 2003 in the Game Manager list. Thank you!
