Time for upgrade 2DOF to 6!!
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by poman, Dec 5, 2015.
  1. poman
    poman Active Member
    154Coins
    Another update, all arduinos connected and recognized by windows, still got to do some finishing touch but ill wait till all is ok, another hour and 2 of the 3 main parts will be joined...to be honest, i cant believe how @SilentChill was able to do all this in bout 2 weeks!!!! it is WAY more work than i tought even if i knew it was going to take some while, one who hadnt made one doesnt know how much work this is, Grats to all who did one (Applause) but it is surely going to be woth the effort :)
    I also got an e-mail yesterday from HTC that my VR helmet's order is in process... whoooooo!!!!
    P.S. gonna have a permanent chrisstmas tree in my living room LOL!!
    20160327_114207.jpg 20160327_114220.jpg 20160327_114235.jpg 20160327_114254.jpg 20160327_114402.jpg 20160327_114432.jpg 20160327_114443.jpg
    • Winner Winner x 3
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    Very clean look to your "Christmas tree" don't forget to cool those mm's. They won't survive long without it. Looking forward to seeing it in action.
    • Agree Agree x 3
  3. Pit
    30,501Coins
    Can't underline it enough - w/o cooling they will suffer and die faster than you can ride your rig...
    • Agree Agree x 3
  4. poman
    poman Active Member
    154Coins
    see my post 97, guys dont worry !!!
    I have $100.00 worth of coolers on the way :)
    • Funny Funny x 2
  5. SilentChill
    20,598Coins
    Nice work coming along nicely :)
  6. poman
    poman Active Member
    154Coins
    Hey!!
    Here they are !!! the "Coolers" (didnt ment to be funny with that but ...what the heck LOL)
    Chineese stuff is definitly not reliable, darn, i cant finish the job as they put only 9 1/2 mounting hardware kit for 12 heat sink...at least they are wired, and the cutting to make them fit was quite some work, i had to try 3 different tools(dremel) with different attachement as they get quickly filled and dont cut, good thing i have access to a shop with lots of tools :)
    • Like Like x 6
    • Winner Winner x 4
  7. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    @poman this is nice clean work. Very impressive :thumbs
  8. wannabeaflyer2
    london uk
    8,351Coins
    Dammm :) Man in any language that's impressive stuff , very nicely done ... :cheers
  9. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Really great work man, congratz.
  10. Nick Moxley
    For Sanding on Aluminum like that and not Flat edge shapes that a Cut off wheel could easily do, your best weapon would be a Coarse Followed by a Fine Sanding Drum, Trick is to be Patient, NOT to rush the job and Clog up the drum real quick, As if your not wise or keen to Ebay and bulk buys, Dremel Brand Name Sanding drum's will kill you in price for a 6 pack.
    A 100 pack of each size/grit is what i stock now, I Blow through them faster than ever before, but for 2-3$ for 100....who the F cares....:cheers
    http://www.ebay.com/sch/i.html?_fro...g+drums.TRS0&_nkw=1/4"+sanding+drums&_sacat=0
  11. poman
    poman Active Member
    154Coins
    TKS a lot guys for your appreciation of my work, YOU are very much responsible for that, i wanted a clean rig due to the fact that it was going to be in my living room, but you guys motivated me to be more precise and clean and it make me proud of myself as in the past, i would have left some rough corner out there!!
  12. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    hi pomen,
    can you tell me how much this 6DOF setup up cost about roughly?
    Best,
    Oliver
  13. poman
    poman Active Member
    154Coins
    Hi @kermitkong , If i dont count the seat frame, just motion stuff, around $2000.00 Canadian
  14. Nick Moxley
    Where are you located again poman ?
  15. poman
    poman Active Member
    154Coins
    In shawinigan city, province of quebec in canada
  16. Nick Moxley
    oh ya just a couple hours away from me....Lol Couple days worth of hours more like. :grin :cheers
  17. kermitkong
    1,240Coins
    @poman, what are the configurtion of the power supplies ? 12V 40A each ? or 24V 20A ?
  18. poman
    poman Active Member
    154Coins
    @kermitkong , 12v 30A, just hope it will be enough, cant test all yet cause i am waiting stuff from china...again :(
    But bare in mind that i WILL have gas strut to help support weight
  19. kermitkong
    1,240Coins
    @poman , ah yeah ! I'm using 24V/20A this is 480Watt per motor, also hope so that is enough . But I think the power and the force is also depends with the gear ratio. My gear ratio is 60:1 .
  20. BondeX
    EE
    Michigan, USA
    1,501Coins
    Hey @poman, could you please post the link of the struts you are getting. Thanks
