Issues with 2016 sketchup
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by marc79, Apr 11, 2016.
  1. marc79
    marc79 Member
    482Coins
    I cant get sketchup updated with the sketchup physics plugin, It does not have the same folders as listed in the tutorial, there is no plugin forlder
    153,770Coins
    +11,149 / 57 / -2
    You need to run Sketchup once to create the directory structure and I have altered the tutorial to note that.
    After you run Sketchup once the folder will be created here: C:\Users\Your_User_Name\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
  3. marc79
    marc79 Member
    482Coins
    Thanks Ill try it again
    153,770Coins
    +11,149 / 57 / -2
    I checked again this morning and did an install and config for the 32bit version of Sketchup 2016 and can assure you it does work.
    Let us know if you have any issues.
  5. marc79
    marc79 Member
    482Coins
    Ok great, if I do cant get it, Ill do a screen capture recording tomorrow
  6. marc79
    marc79 Member
    482Coins
    Noor so I finally did it and saw the plugins opened up once I started sketchup, but then when I close the program and open it later the plugins just disappear, they wont open up again
  7. marc79
    marc79 Member
    482Coins
    Ok my sketchpysics control panel shows a black dos screen on it. I followed instructions, anyone can assist me via Teamviewer please?
    153,770Coins
    +11,149 / 57 / -2
    Just a tip, if you want to ensure a member sees a post then add their user name like this @noorbeast, that way they get an automated notification: http://www.xsimulator.net/community/faq/tag-a-member.73/
    SketchyPhysics is meant to have a black dos screen when it is running. That means it is working.
    I think you mean you can't see the SketchyPhysics control tools, which are free floating when first installed. You can get them back by checking the appropriate boxes by going to the menu View -> Toolbars. I drag the floating toolbars and dock them at the top of Sketchup, like this:
  9. marc79
    marc79 Member
    482Coins
    but where is the slider for the servos so I can control them? I saw in the tutorial it had a control to slide them. but mine is just black. Im talking about the control panel, let me screen shot it
    153,770Coins
    +11,149 / 57 / -2
    Different version, just use SimTools to directly control the model.
  11. marc79
    marc79 Member
    482Coins
    153,770Coins
    +11,149 / 57 / -2
    Just scale down the window and move it out of the way, then use SimTools to control the model directly.
  13. marc79
    marc79 Member
    482Coins
    @noorbeast
    sketchUp plugins folder (C:\Program Files (x86)\Google\Google SketchUp\Plugins). I didnt do this part yet cause I cant find this folder, I think My OS is all messed up or something
    153,770Coins
    +11,149 / 57 / -2
    That is the wrong path for SketchyPhysics files, as per the instructions it is the SketchUp Plugin folder C:\Users\Your_User_Name\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
    Follow the instructions here: http://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
  15. marc79
    marc79 Member
    482Coins
    ok yeah I put, and I seem to have issues control the servo with the game engine still
    I followed everything
  16. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    You need to be a bit more specific, does the default model included with the instructions run with the settings as pictured in the instructions? You turn on SketchyPhysics and the use Output testing to check.
  17. marc79
    marc79 Member
    482Coins
  18. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    I had put this in a PM but am reproducing it here for the benefit of others. You are making this harder than it has to be @marc79 by not using the instructions, pre-configured model and settings provided in the FAQ tutorial: http://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
    Though you are close my suggestion is that you delete the Sketchup folder: C:\Users\Your_User_Name\AppData\Roaming\SketchUp
    Run Sketchup once, which will recreate that folder. Then use the pre-configured SketchyPhysics files, model and settings in the tutorial.
    It is also very important to follow the instructions, it is a bit hard to see in the video but it looks like you have added quotation marks around the Interface Output declarations, when it should be like this:
    You can fiddle with things after you have a working SimTools/SketchUp environment.
  19. SeatTime
    @noorbeast , You truly have the patience of Job. :thumbs
  20. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    thats good you have patience because it will be my turn next haha
