My 6Dof setup - DIY Surge-Sway seat base with Frex Quadmotion
Discussion in 'Commercial Simulators and Peripherie' started by clarkii, Apr 23, 2016.
  1. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Last year I started a thread for my project to convert my Frex 2dof to 2dof + traction loss
    http://www.xsimulator.net/community/threads/simtools-2dof-with-tl-scn5-simvibe.6927/
    Earlier this year I resume my project and want to try out a 6dof setup. I bought extra parts and linear actuators from Frex and built a base 4dof (Frex Quadmotion) for heave + pitch + roll + traction loss (yaw) and on top of it DIY a 2dof platform for surge + sway. Below is my progress so far:
    The six scn actuators including 3 scn6, 2 scn5 and 1 scn5 rodless
    The base is strengthened with frame parts and added carrying mounts so that the whole setup can be relocated if needed
    Triangular base frame with 3 scn6 installed
    2 x 24Vdc & 1 x 48Vdc transformers for driving all 6 scn
  2. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Installed scn5 rodless and swivel base for traction loss
    Traction loss base finished
    Added 2 scn5 for surge-sway platform
    Surge-sway platform finished
    Seat installed
  3. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Video showing initialization of scn in Simtools
    The background noise is from the fan on the Meanwell 48Vdc transformer, really noisy
    My coming tasks will be reconnecting the triple screens, steering wheels, etc and then set up the profiles to test some sims. Questions and comments are welcome.
    • Like Like x 5
    151,620Coins
    +11,043 / 56 / -2
    I will be looking forward to seeing the end result.
    I can't help but be reminded of Sci-Fi movies by the sounds it makes!
  5. kingh3
    kingh3 Member
    256Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Motion platform
    OH, an exciting mechanical playseat. :cheers
    • Optimistic Optimistic x 1
  6. kingh3
    kingh3 Member
    256Coins
    But I think it's a little slow to response with data from main board.
  7. SeatTime
    The actuators are just going through internal setup/initialization.
  8. kingh3
    kingh3 Member
    256Coins
    Maybe set up percent motion of each axis at axis assignment? will you reduce motion of each axis?
  9. SeatTime
    Nice build :thumbs. IMO the squeaking noise from all the stepper motors could get annoying once in use - maybe use noise cancellation headphones:think, or just big speakers..:).
  10. MAYA One
    MAYA One Member
    china
    468Coins
    2DOF, SCN5
    Very beautiful, it is worth learning from the structure
  11. Thirsty
    Thirsty Member
    Brisbane
    593Coins
    Looks very impressive. Don't you think the pedals will have to move with the seat?
    Noise may be an issue though. Looking forward to seeing this thing completed and in action.
  12. Nick Moxley
    17,056Coins
    Very much looking forward to seeing the Surge/Sway table in action. Curious what is the seat sitting and sliding on the plexi ?
  13. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi, I prefer 'seat move only' setup due to the short moving range of the linear actuators.
  14. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi, the surge-sway table is sliding on acrylic boards, I also tried granite boards and found both work fine but granites are much heavier so I am using acrylics right now.
    Hope I can set up the profiles and test out some sims this weekend.
  15. Maddog28
    Maddog28 New Member Gold Contributor
    222Coins
    that is impressive and that gave me the idea to build that one too. I have a question: would you tell me, what the pieces are that you attached at the SCN5 the red/green glide pieces? Where did you find that?
  16. SeatTime
    IMO if this is going to be a seat mover, then I think that the amount of movement available may be an issue with stationary pedals/controls.
  17. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi, the rail blocks & rails are manufactured by HIWIN, a company in Taiwan:
    http://www.hiwin.tw/Products/Products_gw.aspx?type=gw&subtype=gw_hg
  18. Maddog28
    222Coins
    thanks a lot for that. i am really looking forward to see how this will work all together with a driving :) I will build such a thing for sure, using simtools.
    are these SCN5 100mm and the SCLG5 also 100mm?
  19. John Alexander
    John Alexander New Member
    United States - North Carolina
    76Coins
    Great platform, I have been watching the video over and over. How did you come across the idea of building the surge/sway platform with the actuators situated like they are? I am working on a build that just moves the bottom of a seat. Is there somewhere you used as an example / is there a specific name for this type of platform that could help my research.
    Thanks so much!
  20. long legs
    long legs Perfect Race is a perfect day
    teacher
    catalonia
    373Coins
    2DOF, SCN5, Motion platform
    amazing. Is the project finished?
