6DOF moter doubts
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Mike-xu, Apr 24, 2016.
  1. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    rated speed after gearbox: 90 RPM
    ratio: 20:1
    torque: 12 N.m
    power: 300W
    Hi all,
    I have read some threads and I planned to DIY my 6 DOF 12V DC lever based simulator.
    I found someone use wiper moter and some one use worm driver moter, what is the difference? which is better for lever based simulator? and how much power/amps or something else is required?
    Now I'm search moter on-line, I found some moter spec as below, please who can give me some suggestion, thanks in advance.
    • Wiper moter with gearbox:
    ratio: 20:1
    torque: 12 N.m
    power: 300W
  2. Pit
    30,510Coins
    Hi wiper motor and 300W? Can you share the source link?
  3. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
  4. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    @Pit Hi according to your experience, is 12 N.m torque enough for 6 DOF level based simulator or not? thanks.
    153,764Coins
    +11,149 / 57 / -2
    I do not consider 12 N.m torque is really enough, I use 36 N.m on my 3DOF with assisted heave.
  6. Radioproffi
    Lviv
    1,677Coins
    It depends on the length of CTC.
  7. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    Hi, compared with 3 DOF, I understand each motor of 6 DOF system only required about half torque, maybe my understanding is wrong.
    and do you have some suggestion for motor and gearbox type? I see there are different type, like worm drive motor,
    planetary reduction gear motor, etc.
    I'm confused which type should buy.
  8. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    if with 80 mm CTC, is 12 N.m torque enough or not? or how much torque do you suggest?
  9. Radioproffi
    Lviv
    1,677Coins
    12N.m not enough for 80 mm CTC. Even 20 N.m not enough for CTC 65 mm.
    I think, need use 50RPM/18N.m with CTC 40-45 mm
    153,764Coins
    +11,149 / 57 / -2
  11. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    Thanks all, I will read it.
