Generic unity plugin
Discussion in 'SimTools Plugins' started by narthur157, Dec 16, 2015.
  1. narthur157
    narthur157 Member
    258Coins
    Hey I'm thinking about writing a Unity plugin that can be downloaded from the assets store for people who want to easily add simtools support to their games.
    Did some quick searches and didn't find anything, has anybody done something like this?
    What I'm looking to make is a script that you can attach to any Unity game object which will then export telemetry data to simtools. If this is successful, I will later try to do the same for Unreal Engine.
    Looking to do this for some potential games I will be making but to also open source it and such since I'm a comp sci student.
    Thoughts?
  2. value1
    15,060Coins
  3. narthur157
    narthur157 Member
    258Coins
    I'm a continent away from my JRK's and my motion sim right now, is there a way to test game output without actually having a JRK connected? Either a way to make my computer think there's a JRK, or just something that shows game input in simtools? I want to test my UDP communication.
    This looks quite simple to implement.
    EDIT: Just remembered virtual axis...
  4. value1
    15,060Coins
    Use an existing COM-port as "interface", that's enough.
  5. narthur157
    narthur157 Member
    258Coins
    I've verified that I'm definitely sending out data via udp packets (verified via wireshark) to 127.0.0.1 on port 4123, but still no movement on the virtual axis.
    I'm not sure how to debug this...I'm not sure if it's just my simtools config that's messed up, if the packets are not being received by simtools, or if the format is not working.
  6. narthur157
    narthur157 Member
    258Coins
    I made a dump of the process and I don't see that GameEngine is using the Unity.dll module I made, yet I set it in game manager and 'patched' the game (which does nothing essentially, but seems to enable the plugin)
    EDIT: It's possible that my config is messed up because this computer hasn't had the JRK plugged in so the COM ports are unavailable? I'm using the NET interface with a bogus config
  7. value1
    15,060Coins
    The data you send from the unity module must be received by a plugin for SimTools.
    You could send the Unity data in the same format as LFS does and modify the LFS plugin.
  8. narthur157
    narthur157 Member
    258Coins
    I basically did this, except I reduced the data down to a single value, X position.
  9. narthur157
    narthur157 Member
    258Coins
    Update: After mucking with config, I was able to send some roll data. Now it's just a matter of adding all the other axis. I'll upload the code to github soon
    • Like Like x 5
  10. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    This would be really useful, how's it going?
  11. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    Any updates?
    152,451Coins
    +11,078 / 56 / -2
    @narthur157 was last around about a week ago, so hopefully we get some info next time around.
    It would be exceedingly useful to have a Unity Plugin, I would be keen to give it a go with a custom driving experience rather than mod some existing games as I do now.
  13. digital
    digital New Member
    London, UK
    299Coins
    @narthur157 Any movement on this? I'm looking to add support to my Unity project.
    152,451Coins
    +11,078 / 56 / -2
    @narthur157 has not been around since earlier in March, hopefully the unity plugin project will progress when @narthur157 has more time.
  15. narthur157
    narthur157 Member
    258Coins
    Here's my progress, it's not too much, but it is a successful proof of concept. https://github.com/narthur157/motion-sim
    It only gives one axis of something, I forget what. But it's just a matter of exporting the other data.
    Looking at it now though, I think I forgot to add the Unity script, woops...But it just sends UDP packets to localhost to the port given in the plugin for each axis and such.
  16. noorbeast
    152,451Coins
    +11,078 / 56 / -2
    I am so pleased you got to the proof of concept stage, I have bookmarked your work to have a little look when I get a moment.
    Please do let us know when you include the script, I know @digital was following up on people's request to add motion to their game and the likes of @jangomoose and I are currently working on our own Unity based projects.
  17. RusPixel
    RusPixel New Member
    Russia
    138Coins
    Any idea for Unreal Engine?
  18. ferslash
    ferslash Active Member
    4,798Coins
    man you rock !!! keep that nice work, :D (support is not much, but you have plenty of fans now) :D
    @noorbeast i guess you will have movement in your witch fly simulator (man i really liked the demos you uploaded that time)
    best regards to all
    fer
    152,451Coins
    +11,078 / 56 / -2
    The broomstick rides I did for my father's 85 birthday used a modified office chair and mount for the Vive wand, so did not have motion other than transducers. But that is the sort of things where it would be nice to have an easy way to include motion support.
  20. kjjcard
    kjjcard Member Gold Contributor
    south korea
    356Coins
    2DOF, 3DOF, 6DOF
    I found the DLL files for AdditionPlugin and PluginAPI in this project. I put it in the Plugins folder of Unity project and changed Unity to .NET 4.6 version. After that I want to use this project, but I do not know how to use this dll. My motion platform is 2DOF and I want to control both axes. Thank you.
