major wiring help required
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by crammy, Apr 22, 2016.
  1. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    hi guys. as you may or may not know im a newbie and started my own project.
    bits have been arriving and i thought it would be pretty easy. Oh how wrong was I, but you live and learn.
    I generally have no idea how to connect the bits up what i have and what else i need to buy. any help appreciated.
    ive attached some pics of what i have, so if you could help with wiring diagrams and what else i need to purchase that would be fantastic.
    4x frex hyperaxiss 100
    1x scn6 40x150
    5x connectors
    1x48v power supply
    1x24v power supply
    2x usb com 485 boards
    sorry to be a pain but i am clueless and dont know where to start
  2. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    hi all. I've been scouting the forum looking at the SCN6 threads and figured out how to connect them via other peoples descriptions and diagrams. the trouble i am having is the 2 x boards. the type other people have used are different, so have i got the completely wrong item or are there adaptors that go into the com ports that i am missing. I can see absolutley no way of connecting to them.
    Cheers guys
    I really wanted to get set up this weekend
    153,884Coins
    +11,154 / 57 / -2
  4. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    thanks @noorbeast. struggling at the minute. was hoping to be connected today but not looking good at the minute.
  5. SeatTime
    Maybe also contact @Roadster2 as he is the only one that I have seen on this site using Hyperaxis 100s - good luck.
  6. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    thanks @SeatTime. Yhis was the topic that got me into my Set-up. I have bean dealing with @Roadster2 and he is trying to get the last bit of information. I know how to connect it up all except for 4 wires. These are the wires that go into the 485 board. I have ordered 5 female ended DB9 cables that i am going to cut one end off and connect to the actuator. i just want to make sure i connect the right wires as one of the scn6 diagrams uses an RS232-RS 485 converter so just want to check.
  7. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    I think i have cracked it. Lots of searching and i have ordered 5 of these. now to go and buy a couple of miles of cable. hoping to be ready to test and set up with sim tools at the weekend. will be after a lot of help then guys converter.jpg
  8. nclabs
    196Coins
    Avoid multiple port usb-rs485 converter, trust me.
  9. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    any recommendations @nclabs. these seem to be showing up in all the threads
  10. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    Sorry @nclabs. did you mean the multi ports on the rs232-485 pictured above or were you referring to the main 485 board in the thumbnail in first post. Any reason why to avoid as i have the board and the converters will be here today or tomorrow.
  11. nclabs
    196Coins
    The last one you posted it's good I think, I was referring to the first one you posted. Anyway, if you need to drive 5 actuators, you will need 5 of those converters.
    That kind of converter is about RS232 to RS485, but you will need another 5 converters from RS232 to USB. I would prefear a converter from USB to RS485 directly
  12. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    I Have got 5 of those converters so all good there. From speaking with @mrt on his post he has used the same board with no issues so will see how it goes for now before ordering more parts. I didnt so much as want the converter itself, i just wanted the plug board but couldnt find them on there own. Ill keep you posted.
  13. mrt
    mrt Member
    United Kingdom
    719Coins
    3DOF, SCN6
    hi just noticed this thread. If you havent alredy got it. i have a wiring diagram for wiring up the power for the hyper axis @crammy
  14. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @mrt. Im 100% up and running now mate. The power wasnt the problem, it was the com-usb-RS485 board being a 4 way kind
  15. MAYA One
    MAYA One Member
    china
    468Coins
    2DOF, SCN5
    Can provide SNC purchase links. thank you。
  16. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
