New Here...selfmade simulator construction. Actuators needed
Discussion in 'DIY Motion Simulator Projects' started by Tom Theison, Jan 21, 2007.
  1. Tom Theison
    Tom Theison Member
    Machinist
    Indianapolis, Indiana
    69Coins
    2DOF, SCN5
    ....and was'nt sure where to post this as my German is nearly non-existant. I didnt see any way to translate the whole site into english, sorry Moderators, please move this thread if its in the wrong sub menu, thanks.
    I am extremely interested in this software as I have built me a little motion cockpit on my own (link below). You may recognize it as its nearly an exact copy of a Frex simcon-motion cockpit. I do have an Ivibe incorporated into my seat, and was hoping Ivibe would release an update to be able to use the 5 expansion ports on the back of the Ivibe controller to allow use of a couple of electric actuators to power my cockpit up. I am strictly a racing sim addict with GTR2, and rFactor being my main sims right now. I downloaded the software and played around with it a little as a start. Looked over some of the help files and started to get aquainted with it. Like I said, my German reading is 0 so if anyone has done a translation of any of this I would be extremely gratefull for any help.
    Maybe some of you could help me and get me pointed in the right direction as far as what parts and stuff I will need to start learning about. Been reading through the forums here and already I see I am going to need a usb board then look into some pnuematics. I really am only looking to use two cylinders at the back of my seat. Then seeing if acceleration, braking, and steering input can be controlled simultaneously somehow.
    Thank you,
    Tom Theison (aka Tommy Trauma)
    http://forum.rscnet.org/showpost.php?p= ... tcount=100
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Re: New Here...
    welcome to our forum!
    Your cockpit looks great! We have another member in the forum who tries to build such a frame.
    http://www.x-simulator.de/forum/bilder- ... -t120.html
    Maybe you both could exchange some hints. Especially about the pivot point :mrgreen:
    His post is in the wrong thread as well ;) I hope you want to post your frame in our forum. But please in this section:
    http://www.x-simulator.de/forum/bilderg ... r-f20.html
    Afaik BBEL had mentioned to implement support for pneumatic acuators, but not for electric ones!?
    I'm new here as well. Because of that, there are some others here in the forum, who could help you with your x-sim softwarw related questions much better than I can.
    We are about to im implement support for electric actuators in the software. But it will take some time, still.
    regards
  3. egoexpress
    421Coins
    BTW
    if you get an email with:
    Eine neue Private Nachricht ist eingetroffen
    then you have received a pm ;)
  4. RaceRay
    Hamburg, Germany
    23,876Coins
    Hello Tom,
    big nice welcome from me, too :D
    We have translate the forum names. Now, you can navigate through in best german english u ever read. : :wink:
    There are many possibiliities to control your - very nice looking - motion cockpit.
    Here, u will find al the possible interfaces:
    http://www.x-simulator.de/de/hardware/hardware.html
    The best solution is to use the USB Modules K8055D or better the selfmade USB interface
    http://www.x-simulator.de/de/hardware/rnr-usb-interface-3.html[/code]
    The much less solution is the conrad relais interface. Ready to build in, but soft-motion is missing. (soft motion is a kind of wash-out effect. The Actuators drive slowly back in a neutral position, so, that there is enough space for a new movement.)
    regrads
    RaceRay
  5. thomas earl
    thomas earl New Member
    IL-USA
    0Coins
    im new too....
    and im gonna need a whole lot of information.i do have some german in my language skills,its not what it used to be.
    lately it came to mind to build a race simulator.
    everywhere i looked on the net it seemed everyone is jacking arround to make it move.(as i'm in the states i never heard about the RnR).
    i remodeld the basement to make room for this apperatus.
    my tech skills are above avg.and know very well about contructing things.
    my only real problem is the usb interface.(in this area everything sounds jibberish to me).So i defenitly need some help there.
    now just a few questions to start it off.
    1) where in the states can i get a couple of those usb interfaces?
    2)what kind of pneu valves do i need and how many?
    3)what size of cyllinders do i need and how many?
    tom t
    i like your setup you are my insperation lol.
  6. egoexpress
    421Coins
    Re: im new too....
    Hi Tom
    Welcome!
    Its quite difficult to say it with a few words.
    I think I'll better continue to translate the hp, instead of explaining every new member the whole setup ;)
    Your questions:
    1. which, there are different. A friend of mine will assemble some USB 1.3 interfaces. If you are interested > http://www.x-simulator.de/forum/group-o ... 3.html#913
    2. How many valves you need depends the brand and model.
    3. For a 2-axis simulator you'll need 2 cylinders. The size depends on the setup. For a RnR is 300mm and for a Frex-like setup is 100mm recommended.
    We are quite busy with the electric actuators project in the moment, so be a little patient please.
    regards
    ps: please open a thread for your project; it hard to find threads that are started in another threads
  7. RaceRay
    Hamburg, Germany
    23,876Coins
    thread was moved...
  8. thomas earl
    IL-USA
    0Coins
  9. Tom Theison
    Tom Theison Member
    Machinist
    69Coins
    2DOF, SCN5
    Yeah, that setup is pretty nice. Thanks for the link.
  10. egoexpress
    421Coins
    Yes, its really interesting. But I dont think that its software supports common games. Maybe they have just an own arcade game for it. Dont know.
    cheers
