Compatible Actuators ?
Discussion in 'SimTools compatible interfaces' started by SUPERSLOT, Nov 4, 2008.
  1. SUPERSLOT
    SUPERSLOT New Member
    9Coins
    Hi all
    On my research on web i found this italian actuator, for me is good.
    Is this actuator compatible with tronic motion controller and h-bridge and x-sim software ?
    The electric characteristic is similar to firgelli but the performance is more interesting.
    Thank for your response
    :D
  2. tronicgr
    tronicgr
    From electrical matter, they will work, but is the speed they have, true? 317 mm/s ??
    My joyriders actuators, for example, has speed of 40cm per second!
    Thanos
  3. SUPERSLOT
    9Coins
    Hi Thanos
    Thank you for your response, Also I am still surprised from the velocity performance.
    Now i phone to this company for more information and then i post the information to the community.
    If the performance is true this actuator is very interesting
    Bye
  4. SUPERSLOT
    9Coins
    Thank you Sirnoname
    I have found another actuator of this italian firm, with a cc motor with power 150 w.
    But it is possible to control this motor with a thanos controller and x-sim 1 ?
    Thank you
  5. tronicgr
    tronicgr
    Yes, I believe my DSMhb1.2 (h-bridge driver) will be able to drive fine this 24volt 9Amp motor.
    But You have to add temperature probes to the mosfets and watch the ampere rate with an amp monitor gauge. Normally you should have temperatures ranging from room temperature to max 45-50 degrees of Celsius.If you keep the ampere to the motors specifications and be careful not to stall the motor, it will be fine. Another thing to watch out is to use separate power input cables for each motor to avoid overheating and eventually burning of the cabling. Not all cables are capable of letting 20ampere pass through them!!
    And yes, you can use my AMC1.5 and DSMhb1.2 with both old x-sim profiler1.8 and with the new xsim2 profiler2.0 , later! :thbup:
    Thanos
  6. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    For which purpose do you want to use those motors?
    The speed and kgf requirements depend on the application.
    Regards
    Christian
  7. SUPERSLOT
    9Coins
    Thank Thanos and Egoexpress
    I think about using this actuator on Frex like simulator, now I am waiting for the price that I have not received yet.
    I hope that the price is competitive in comparison to SCN5.
    Bye
  8. RaceRay
    Hamburg, Germany
    23,891Coins
    Superslot,did you get the price for your mentioned actuator?
