budget bass shakers from ebay
Discussion in 'Electronic and hardware generally' started by pipis2015, May 3, 2016.
  1. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    • Useful Useful x 3
  2. Pit
    30,490Coins
  3. ferslash
    ferslash Active Member
    4,798Coins
    how do you drive it?
  4. Pit
    30,490Coins
    Simvibe, but SimTools 2 is on the way which will support body shakers as well.
  5. SilentChill
    20,592Coins
  6. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 10Coins
  7. Nick Moxley
    17,056Coins
    That amp you linked is a Mono Single channel amp, so Not really ideal, pending what your doing of coarse. You dont need crazy wattage to power the small shaker's, your better off with less wattage and more channels to later on be powered by Simtools 2.0 for a "Chassis" or "Extension" setups.
    • Informative Informative x 3
  8. asteroulis
    asteroulis New Member
    174Coins
    DC motor
    For anyone interested these are indeed VFM , as long as cooling is taken into consideration. They shouldn't be place somewhere too tight.
