Showroom 6DOF racing platform 12v dc 3.6kw arduino and mm/SMC3
Discussion in 'DIY Motion Simulator Projects' started by bruce stephen, May 3, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    gathering parts and supplies at this point.
    UPDATE:This is the most recent photo 7/13/16
    • Like Like x 7
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    So the concept is much like other Stewart platforms. I will add a surge plate to the seat (seat mover style) utilizing a seat adjuster. I am going to attempt to move the center of gravity to waist height for added leverage. The front mounts (knee) will be separated a little also. this is a very early sketch and Ive already made some changes in my mind and it is very basic so don't be too harsh lol.
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
  4. Nick Moxley
    17,056Coins
    That NRG is what a buddy bought, Imo not the most comfortable thing ever....but a thicker pad/foam could be sourced if needed. I personally found it a little hard on the back side compared to mine.
  5. MAYA One
    MAYA One Member
    china
    468Coins
    2DOF, SCN5
    Early success!!:cheers
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    Thank you for the heads up. Unfortunately they sold it to me, charged me then sent me an email 3 days later staying they were out of stock and would give a refund. So the seat search continues............
  7. Pit
    30,490Coins
    @bruce stephen whish you great success, very interesting project! Subscribed!
  8. Historiker
    9,208Coins
    Finished yet?! :)
    • Funny Funny x 2
  9. Rocco
    Rocco New Member
    Phoenix, AZ
    83Coins
    What type of motors are you using?
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    bodine
    I may use a worm gear motor for the seat surge though. the bodines are 13 lbs each so id like a smaller, lighter one considering it will be on the platform.
    edit: also added a pic (above) of my rod ends and pots, the extra 360s are for scaling
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    more stuff showed up yesterday so im beginning testing and wiring
    had a couple hours to spare today so i cut and welded the base frame. it measures just a little over 5 feet wide.
  12. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    a big project.:popcorn
  13. Rocco
    Rocco New Member
    Phoenix, AZ
    83Coins
    A trio of Arduinos! How many motors can a single Ard control? Looking forward to seeing your progress. :)
  14. Pit
    30,490Coins
    Depending on the code and motor drivers up to 4 motors (afaik)
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    I'll be running 6 ards total.(max interfaces for STv1.3 and v2) Just one per motor except for the surge which will be added as a second motor on one of the ards. Thought is less load on each ard = faster processing. Maybe it doesn't matter tho.. But I'd possibly like to mount each controller at each motor then run the spaghetti through the base frame. But we will see I may make a separate pit box style enclosure to hold all of the power supplies and controllers. I haven't decided yet. I've got a busy weekend but I'll get some time to mess with the monsters. I got them soldered and ready to be load tested last night so that is probably next.
  16. mariana fino
    mariana fino
    waiting for the vídeo,good job!!!
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    I threw this together to save me some future hassle testing my monsters.
    Update: 12 for 12 no bad apples. :D
    Edit: The test bench was made using a project box I got at radio shack awhile ago, an arduino uno r3, an adafruit pi half size Breadboard, two 10k potentiometers, three plugin posts from a shield kit.
    I then drilled out the holes for the monster plugs to sit using a 1/8" bit, bent the posts I wasn't using to help hold them in place. Next I hot glued them in place along with the uno and breadboard. I then drilled the holes for the pots and wires. The wires were then connected. I also added a small dc volt indicator to the 5v. it is wired for two motors to make it easier to isolate a bad side and get them hot quick.
    build time 30min.
    • Creative Creative x 5
  18. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    i'll like to see the final results, you got some heavy duty parts. :popcorn
  19. RacingMat
    21,047Coins
  20. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Thanks for sharing this, its going to be an interesting one to follow
