Tutorial How to write a Game Plugin for SimTools 1.0 - API documentation
Discussion in 'SimTools Plugins' started by yobuddy, Aug 6, 2013.
  1. sanny
    sanny New Member
    Slovenia; Switzerland
    166Coins
    Not Sure if you already solved the issue, but I got the same error if I forgot to build the application before compiling it (Build->Build Solution).
  2. PaulMac000
    PaulMac000 Member
    26Coins
    Motion platform
    Ha! Thank you! That helped me a lot. I knew there was something wrong when it kept debugging and none of the files were been updated.
    Kudos.
  3. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    How could I know if a game use the telemetry needed to do a new plugin?(I would like to try with Midnight club racing II)
  4. Chriss
    Chriss IntMech
    Bolivia
    86Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    Hi all, I see that many want compatibility with FPS games, these games do not have telemetry rotation, only have positions x, y, z, if you want to develop plugins for FPS, I advise, find a way to extract information rotation of the bones, by the vast majority of the games are 2 essential bones, the base point and the hip, if you want to make a simulator for these games, use one of these bones to extract the telemetry, the best way would be to use the two hip to the rotation and the base point for the movement.
    I hope you serve my answer ...
  5. PaulMac000
    PaulMac000 Member
    26Coins
    Motion platform
    Further to that point, there is a cheat engine tutorial on youtube where he extracts the x,y,z positions of the main character:
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Here are my errors....help please?
    Code:
    Severity    Code    Description    Project    File    Line    Column    Suppression State
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.GameEnd()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.GameName'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash10_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash11_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash12_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash13_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash14_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash15_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash16_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash17_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash18_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash19_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash1_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash20_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash2_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash3_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash4_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash5_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash6_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash7_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash8_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
    Error    CS0535    'GamePlugin' does not implement interface member 'IPlugin_Game.Get_Dash9_Output()'    iRacing_GamePlugin    C:\Users\Shannon\Desktop\iracing export\iRacing_GamePlugin\GamePlugin.cs    19    29    Active
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    am I able to decompile a dll and make changes then recompile?
  8. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,034Coins
    Arduino, 4DOF
  9. kpocc
    kpocc New Member
    Ukraine
    149Coins
    Hi!Where i can see Memory hook adress in my game?
    151,668Coins
    +11,045 / 56 / -2
  11. AlexinChina
    AlexinChina Member
    China
    371Coins
    Do you sucess? Can u help me ?I really want to make a plugin for mxgp2.
    https://www.xsimulator.net/communit...er-simulation-plugin.4777/page-23#post-111119
  12. value1
    15,007Coins
    Hi @AlexinChina
    I mean, feel free to develop a memory hoock plugin for NLS.
    However just to mention: The NLS plugin already provides surge, sway, heave acceleration, pitch, roll and yaw.
    Also NLS provides a proper API (application programming interface) which is documented in the Help file of NLS
  13. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  14. AlexinChina
    AlexinChina Member
    China
    371Coins
    If u can't teach me how to make it ,Can you give me the code of plugin for this game? I think it will help me also.
  15. Claudio Bello
    Claudio Bello Member
    Brasil
    273Coins
    as I do a sonic plugin all star racing I already have some telemetry data grateful pointer ....
  16. Lodewijk
    Lodewijk Member
    Engineer
    South Africa
    597Coins
    4DOF
    @yobuddy, great writeup!
    Can anybody enlighten me as to which example to study for il2 cliffs of dover, do I look at:
    1) UDP Packets,
    2) Memory Mapped Files
    3) Memory Hooks or
    4) DDL?
  17. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I'm trying to create a plugin for F1 2016, but while trying to patch, I am getting this error;
    The game is installed, and I am attempting to change the LFS plugin. Being a Codemasters game, I would need to patch the F1 2016 folder in my documents, but no matter what I seem to type in the validation string, I cannot get it to patch. The plugin is nowhere near done, I was just testing to see if I could actually work out how to make Simtools create the patch in the correct location.
    Go easy on me as I am trying to learn :)
    Cheers for any help.
  18. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    Hi I'm just starting to learn about plugins myself my best guess is there's something that still points the LFS left in the plugin you have made so it thinks it's not installed ( just a guess I'm new too lol)
  19. Sarge
    - 181Coins
    Hi Daguru,
    I thought that too, but can't seem to see anything. It would be handy to know the procedure with Codemasters games, as you are not pointing directly at the .exe
    Thanks for the advice though :)
  20. Rudolf Jan Horak
    Rudolf Jan Horak Member
    Simulator Maintenance Student
    Devils Lake, ND
    274Coins
    Motion platform
    This is awesome! I had no idea that you can write your own. This may be worth a try. Thanks for the great tutorial
