Brazilian 2Dof
Discussion in 'DIY Motion Simulator Projects' started by Marcos Soares, Jan 17, 2016.
  1. Marcos Soares
    Marcos Soares Member
    Mecânico Split sistem
    Rio de Janeiro - Brasil
    111Coins
    i am just a mechanical of air conditioner and my English are not very good but i will try to show what i doing.
    20160117_190421.jpg 20160117_190351.jpg 20160117_185902.jpg 20160117_185849.jpg 20160117_185827.jpg 20160117_185803.jpg 20160117_185754.jpg 20160117_185730.jpg 20160117_185722.jpg 20160117_185706.jpg 20160116_085129.jpg
  2. Pit
    30,510Coins
    Hi Marcos
    Good Luck with your project. Which Arduino code you are using with? BTW your frame is expected to be very sluggish - the front part will twist due to the weight of it.
  3. Marcos Soares
    111Coins
    i folow the tutorial of RacingMat
    I am working in it, thanks for your opinion.
  4. Marcos Soares
    111Coins
  5. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Im willing to bet that you bend those threaded rods you have connecting to the mounts and the motors.
    • Agree Agree x 3
  7. Marcos Soares
    111Coins
    yes, I will try to use the motomoster in parallel.
  8. Marcos Soares
    111Coins
    i will see if the threaded rods need to be replace for another strong one.
    153,722Coins
    You could just weld the correct sized nut either end of some square tubing and run the exiting threaded rod through it and add a lock nut either end, that would be enough to reinforce it.
  10. eaorobbie
    20,502Coins
    Spot on,
    To make her look sexy , S/S Nut , S/S Washer - S/S 19mm-3/4" Curtain Rail (~2-3mm thick) and repeat washer and nut.
    Im a welder so I TIG weld the washers in place and polish all the weld off, Looks like im using a solid 19mm S/S bar but its hollow and not to heavy to take power away from the motors and super strong and SEXY.
    Ill post a pic but last set I made, mate stole them, well paid for them and I got my old square bars back on , not sexy at all.
    But same idea as @noorbeast but sexy polished look.
  11. Marcos Soares
    111Coins
    The intention Listen And the view from you guys and make the necessary changes. I'm not in a hurry, and be assured that I am grateful for the responses. I will continue posting updates.
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    did you decide which arduino code you will use to drive the monsters? I would suggest the SMC3 as it has a config utility.
  13. Marcos Soares
    111Coins
    Hello, i am start tests with my machine but i need help. I study a lot but i making somethink rong because its dont work. I am using Racing mat code with only one computer, win 10. Can some one guive me a tutorial? Sorry but its means very dicult to me.
  14. Pit
    30,510Coins
    Try the SMC3 code, it's easier to get it working (configuration utility).
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    If you want to stay with @RacingMat code (there is nothing wrong, the code works like a charm), then you should read the manual written by the Guru himself ;)
    http://www.xsimulator.net/community/threads/arduino-code-for-4dof-and-1-dirpin-hbridge-board.4614/
  15. Marcos Soares
    111Coins
    OK, like Racingmat tutorial i start the machine on test. The motors turn on , when i turn the pot nothing hapen the motor dont stop or change velocity. I will change the pot for another and make test again
  16. mariana fino
    mariana fino
  17. Marcos Soares
    111Coins
    i change the pots and the motors trun right and left and change velocity too but only one pot gives the order the other dont do nothink. they have to work alone but they are working togheter in the same way.
  18. Marcos Soares
    111Coins
    sorry for my english
  19. Pit
    30,510Coins
    After filtering out your issue (so far from what I understood) I think you should control the polarity of your pots (again)
  20. mariana fino
    mariana fino
    Check your arduino code and confirm the pot conections !
