Showroom x4 scn6 actuator setup pics inside
Discussion in 'DIY Motion Simulator Projects' started by Adrianstealth, May 17, 2016.
  1. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Hi all
    This is pretty much finished, I just need to do a bit of cable tidying & add a pedal height adjustment mech
    Seat movement (2 actuators)
    Rear skid. (1 actuator )
    Overall pitch (1 actuator )
    X3 buttkickers
    Damping mechs at bottom of each actuator was produced after several prototypes and much testing,
    These are adjustable , scn6 covers laser cut and powder coated for a nice professional finish
    Pedals custom made, bodnar V2 simsteering, Kirky seat (very lite weight)
  2. RacingMat
    21,066Coins
    good! the tubes look very stiff: your sim will be precise in the movements
  3. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Thanks yes that's the idea, its box tube -I spent a few days welding it all together at my local welders!
    I couldn't stand any flex which results on loss of motion detail
    Love it!
    152,971Coins
    +11,115 / 56 / -2
    Nice job :thumbs
    When you get the chance please do add a little more detail about the custom pedal build.
  5. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Ok Noorb I will
    Its a real car pedal set with hydraulics, quite simple to build really ,
    Cutting the hose is the part that's not so nice
    Simply assemble the pedal level parts with the hydraulic parts (all real car parts) and add a pressure sensor into the system going to a circuit (in my case a Derek spere board, a bodnar board would do it too )
    For the accelerator & clutch a standard potentiometers for each (I used leo bodnar ) , I also used little levers that are meant for RC cars, these pots wire to same circuit as pressure sensor
    Takes some time to build but not complex, of course they feel totally real
  6. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Hi
    got everything setup, also have the DCS plugin loaded and DCS world (steam version) patched successfully
    the game manager changes to blue "game running" mode when I start DCS
    but zero motion
    I have checked my Axis under the test mode and they move with the sliders,
    I have turned off windows firewall completely
    any idea's )-:
    152,971Coins
    +11,115 / 56 / -2
  8. GR88
    GR88 Member
    M.E Student
    USA
    644Coins
    Do you have any more pics of those pedals? Looks like your using the Tilton 600? What are you using to give you clutch feel?
